ThomasHayden
Post subject: Re: 1st Tune Posted: Tue Sep 08, 2015 6:29 pm |
Joined: Sat Jul 14, 2012 3:49 pm Posts: 292 Location: South East london Vehicle: MPS3 mkI aero
Been thanked: 9 times
Bhp: 265
Rear engine mount can be bought from over here from as little as £75 I believe it's the same as a focus st Or could get from the states but i would personally order a few bits so you don't get stung on the import tax
_________________ k&n typhoon.. Cobb v3 Auto tech internals Wind deflectors Sonic tuning coilovers J-tuned
to come.. 2nd decat Bigger brakes
jedi ronin
Post subject: Re: 1st Tune Posted: Tue Sep 08, 2015 6:40 pm |
Joined: Sat Feb 06, 2010 12:11 pm Posts: 3322 Location: area 51 Vehicle: MPS3 mkI
Has thanked: 268 times
Been thanked: 62 times
Bhp: 2
lbf·ft: 5
corksport jbr take your pick?
_________________ A Mazda man can!!
jedi ronin
Post subject: Re: 1st Tune Posted: Tue Sep 08, 2015 6:44 pm |
Bhp: 2
lbf·ft: 5
ThomasHayden wrote: Rear engine mount can be bought from over here from as little as £75 I believe it's the same as a focus st
Or could get from the states but i would personally order a few bits so you don't get stung on the import tax that depends on how much you order, you will get stung for the over all value of the orders
Ivegotaveyron
Post subject: Re: 1st Tune Posted: Tue Sep 08, 2015 6:49 pm |
Joined: Sat Jun 13, 2015 8:07 pm Posts: 164 Location: Bournemouth Vehicle: MPS3 mkII
Been thanked: 7 times
Bhp: 395
lbf·ft: 385
no UK companies for these parts?
_________________ Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
Post subject: Re: 1st Tune Posted: Tue Sep 08, 2015 7:03 pm |
Ivegotaveyron
Post subject: Re: 1st Tune Posted: Thu Sep 10, 2015 4:12 pm |
Bhp: 395
lbf·ft: 385
ordered the Vibratechnics part....... I've been hearing a slight noise when letting the clutch out a little fast. I'm assuming its a slight rocking in the mount... I'm sure time will tell
Ivegotaveyron
Post subject: Re: 1st Tune Posted: Sat Sep 12, 2015 6:20 pm |
Bhp: 395
lbf·ft: 385
just had the viber technics rear engine mount fitted...... certainly makes a difference. yes, a little more vibration at idle and when you blip the throttle lightly you can feel it, but the difference it makes to smoothness and gear changes...!! worth the small investment
SilverSport
Post subject: Re: 1st Tune Posted: Sat Sep 12, 2015 6:43 pm |
Joined: Thu Feb 27, 2014 3:56 pm Posts: 665 Vehicle: other
Been thanked: 15 times
Nice, I've been thinking of one too. Has it made the gear change quite a lot better? I guess its a lot better when making progress too. Did you fit it yourself?
Ivegotaveyron
Post subject: Re: 1st Tune Posted: Sat Sep 12, 2015 7:06 pm |
Bhp: 395
lbf·ft: 385
Yeah mate smoother though the gears. No my mate is chief mechanic at a Mazda main dealer. But it's a very easy job. I'd have done it myself but don't have a proper jack or torque wrench.
Post subject: Re: 1st Tune Posted: Sat Sep 12, 2015 7:31 pm |
No need for a torque wrench, just make sure its FT (fucking tight) lol...
Infuzed
Post subject: Re: 1st Tune Posted: Sun Sep 13, 2015 12:08 am |
Joined: Tue May 20, 2014 11:36 pm Posts: 688 Location: Berkshire/Buckinghamshire Vehicle: MPS3 mkI aero
Has thanked: 16 times
Been thanked: 16 times
lbf·ft: 340
SilverSport wrote: Nice, I've been thinking of one too. Has it made the gear change quite a lot better? I guess its a lot better when making progress too. Did you fit it yourself? Makes a big difference, a very worthwhile mod tbh.
_________________ Current Mods :: K&N Typhoon SRI :: Corksport TIP :: Powerflow 2nd Decat :: Forge V1 BPV :: ASI TMIC :: Cobb 3-Port :: VibraTechnics REM :: Koni STR.Ts (Rear) :: Rainsport 3s :: (J-Tune In Progress)
Selling up :( ::
Users browsing this forum: No registered users and 3 guests |
