Benbee
Post subject: Here weeeeee go! Posted: Tue Jun 16, 2015 3:02 am |
Well I finally took the plunge, after my Hyundai failed it's mod on 2 pages (  ) I decided I'd buy an MPS 3 MK1 today, so I did! been driving around for 6 hours and can honestly say I'm thrilled to bits. It's a bit of a fixer upper with bits and bobs needing doing but nothing urgent. Roll on saving for the first mods - thinking headunit/gauges and a butterfly valve. Oh, I'm Ben, by the way.
Post subject: Re: Here weeeeee go! Posted: Tue Jun 16, 2015 11:05 am |
 along
Post subject: Re: Here weeeeee go! Posted: Tue Jun 16, 2015 1:34 pm |
 Ben. Butterfly delete you mean?
Gouldy
Post subject: Re: Here weeeeee go! Posted: Tue Jun 16, 2015 2:35 pm |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
Hi Ben  along to
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
Benbee
Post subject: Re: Here weeeeee go! Posted: Tue Jun 16, 2015 6:31 pm |
Sir-SpamFace wrote: :welcome: Ben. Butterfly delete you mean? Possibly! This is my first turbo car so I'm new to all things FI, but I want the typical chatter noise when lifting off.. BOV instead of butterfly?
Jim
Post subject: Re: Here weeeeee go! Posted: Wed Jun 17, 2015 10:52 am |
Been thanked: 55 times
Benbee wrote: Possibly! This is my first turbo car so I'm new to all things FI, but I want the typical chatter noise when lifting off.. BOV instead of butterfly? Ben I think you have some reading to do  welcome to  though  There are no butterflies involved though.
Post subject: Re: Here weeeeee go! Posted: Wed Jun 17, 2015 11:00 am |
Ah I get what you mean now. You can't run a BOV on these cars as they require the air to be measured the recirculated back into the system to get the correct amount of air to fuel ratio (AFR's) Well, saying that, it can be done but is far from cheap. Including the BOV you'd be looking at spending £400+, for the sake of a bit of noise. There are however adjustable recirc valves that you can get away with that dump a % of air out while allowing enough air to recirc to keep the engine happy. A GFP one for example
Benbee
Post subject: Re: Here weeeeee go! Posted: Wed Jun 17, 2015 11:28 am |
Sir-SpamFace wrote: Ah I get what you mean now. You can't run a BOV on these cars as they require the air to be measured the recirculated back into the system to get the correct amount of air to fuel ratio (AFR's) Well, saying that, it can be done but is far from cheap. Including the BOV you'd be looking at spending £400+, for the sake of a bit of noise. There are however adjustable recirc valves that you can get away with that dump a % of air out while allowing enough air to recirc to keep the engine happy. A GFP one for example Thanks for that! Most of my questions will be turbo related in afraid! With that in mind I'll go ahead and skip the bov and jump into upgrading the fuel pump, that seems like the common consensus as a starting point
Benbee
Post subject: Re: Here weeeeee go! Posted: Wed Jun 17, 2015 1:34 pm |
Charnocknth
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 10:15 am |
Joined: Thu Jan 31, 2013 10:02 pm Posts: 205 Vehicle: MPS3 mkI
Has thanked: 3 times
Bhp: 400
you can still get a good wooshing noise from a forge recerc and sri/tip
_________________ BNR3,snow stage 2 meth injection  , 3"HTP induction, HDI GT2 PRO FMIC, jetex cb, ATP LDP, 3bar map sensor,Grimmspeed EBCS Electronic Boost Control Solenoid, forge v2 recerc, autotech HPFP, silicone return hose, silicone radiador hoses, small battery tray, stoptech drillied/slotted discs front and back, painted callipers front and back, wrapped bonnet and wing mirrors, tinted rear windows, custom side mount number plate holder, custom reupholstered seats and door cards, dipped centre console,AEM digital/analogue boost gauge-oil temp/pressure gauges, road angel jem, mio incarr cctv, built in freeview, bluetooth parrot kit, satnav, iPod connectivity, new age auto glow in the dark spider gear nob, polly ARB bushes front/rear,front whiteline strut bace, BC racing colliers, VVT
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 10:46 am |
It's HPFP internals you want, not a new pump. Take this advice on board, stay away from totalmps, turbo pacs, BBRgti, litchfield. Check out my sig for reasons on total.
Benbee
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 12:04 pm |
Charnocknth wrote: you can still get a good wooshing noise from a forge recerc and sri/tip What's an sri/tip?
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 2:18 pm |
Benbee wrote: Charnocknth wrote: you can still get a good wooshing noise from a forge recerc and sri/tip What's an sri/tip? Short ram intake, turbo inlet pipe
Benbee
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 2:19 pm |
Ah I'm with you now, need to update on my acronyms! I've ordered some prosport gauges yesterday. Just need to source a center dash triple pod if I'm avoiding total MPS but I'll do that this weekend s
Post subject: Re: Here weeeeee go! Posted: Thu Jun 18, 2015 4:42 pm |
IIRC you can get them from states for £30
