Page 1 of 4 [ 50 posts ] Go to page 1, 2, 3, 4  Next
 Post subject: A beep at high speed/high revs.... What is it?
 Post Posted: Sat Jan 31, 2015 4:47 pm
Bhp: 292
Hi guys,
Another newbie owner of mk 1 3. Today while battering and Gti :D there was a beep while I was doing about 120 and 5.5-6 revs. Is this normal, as haven't heard it before. Did freak me out a little at that speed!!
D
 Post subject: Re: A beep at high speed/high revs.... What is it?
 Post Posted: Sat Jan 31, 2015 4:52 pm
Not sure bout mk1 but on mk2 u can set a speed limit and it beeps wen u hit it....
 Post Posted: Sat Jan 31, 2015 4:55 pm
Is that OEM software or modded?
 Post Posted: Sat Jan 31, 2015 5:07 pm
OEM
 Post Posted: Sat Jan 31, 2015 5:44 pm
Just go onto preferences on the screen and turn it off.
 Post Posted: Sat Jan 31, 2015 5:49 pm
Been thanked: 9 times
I've never seen this option on my mk1...
Mods: JBR SRI/TIP || JBR Shifter Bushings || SF SSP || Custom 2nd Decat + Silencer || Forge v2 BPV || Cobb v2 || J-Tune || Bilstein B8
 Post Posted: Sat Jan 31, 2015 6:01 pm
Sorry never read that it was a mk1
 Post Posted: Sat Jan 31, 2015 6:07 pm
Has thanked: 25 times
Been thanked: 122 times
I've never heard a beep in my mk1
Sent from my XT1032 using Tapatalk
Now: 2005 Corolla T-Sport
 Post Posted: Sat Jan 31, 2015 6:08 pm
Bhp: 294
lbf·ft: 324
I've never heard mine beep
true red mk1 3MPS, Hypertech tune, Corksport SRI+TIP, Resonator and 2nd Cat removed, Powerflow custom exhaust, Turbosmart BPV, J-Speed short shift plate, Lowered 40mm H&R springs, Gloss black RX-8 alloys, Mazdaspeed stubby carbon Ariel, XCarlink.
 Post Posted: Sat Jan 31, 2015 7:01 pm
Been to 150 in my 6 and never heard a beep either
BNR S3, HTP 3" intake, 200cell catted Downpipe, ETS TMIC, Autotech HPFP internals, Forge v2 Recirc, Remus CatBack Exhaust, Port/Polish Manifold and TIG, Throttle Body Coolant Bypass, SURE REM, Turbine Tech Front Diff Mount, CPE rear diff brace, Whiteline RARB, JBR SSP
Image Tuned By Justin
Up Next: Rust Removal! OCC, Handling of all kinds!:thumbs:
*A car is just Fast enough when you stand in front of it in the morning and are afraid to unlock it*
 Post Posted: Sat Jan 31, 2015 7:38 pm
Never been over 100 mph [DISAPPOINTED FACE]
 Post Posted: Sat Jan 31, 2015 7:48 pm
Never been over 100? That's poor. You're missing out
 Post Posted: Sat Jan 31, 2015 7:52 pm
Don't fancy getting points :lol:
Sent from Sony Xperia Z Ultra using Tapatalk :thumbs:
 Post Posted: Sat Jan 31, 2015 7:53 pm
Don't get caught. Logging takes you over 100
 Post Posted: Sat Jan 31, 2015 8:02 pm
So do u never do 40 in a 30????? That will still get u points...
I've had mine at 140 but cobb told me I was doing more like 130
Sent from my iPad using Tapatalk
