Trem
Post subject: Hi All Posted: Fri Apr 13, 2012 4:56 pm |
Joined: Mon Dec 26, 2011 10:58 am Posts: 217 Location: Staffordshire Vehicle: MPS6
Hi lads 'n' Lasses, hopefully getting a 6 MPS this weekend so any buying advice or what to look out for greatly appreciated. Cheers.
sdg_3mps
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 4:57 pm |
Hello &  .
Coop
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 5:13 pm |
Joined: Fri Feb 26, 2010 4:10 pm Posts: 3437 Location: Northumberland Vehicle: MPS6
Hi & welcome mate.
_________________ ZZB March 2013 :(
Gavin
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 5:19 pm |
Joined: Mon Jan 30, 2012 9:49 pm Posts: 7622 Location: scarborough Vehicle: other
hi and welcome, do a long idle test at least 10 mins and listen for any vvt issues and thats about it.
_________________ MPS KILL COUNT 1 MK1 3. twice 1 six
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 5:22 pm |
 just do your normal checks as you would when buying any car. Check that there is no smoking at idle after a few minutes for turbo issues. The mps can be quite a noisy engine so be prepared to expect some noises. There is a vvt fault to be aware of which can be expensive to fix so get a decent warranty if you can. There may be some other things that i have forgotten which others will mention soon.... Edit @ gavin you were typing quicker
rusty2503
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 6:27 pm |
Hello and
Trem
Post subject: Re: Hi All Posted: Fri Apr 13, 2012 7:46 pm |
Cheers lads, appreciated.
Apparently the VVT and timing chain were replaced last year but the invoice has been lost. Will go and view the car and hopefully the guy will be able to find it/get a duplicate from the Mazda dealer that did the work (it is a private sale).
daviemps
Post subject: Re: Hi All Posted: Sat Apr 14, 2012 8:04 am |
Hello and
