Page 1 of 2 [ 22 posts ] Go to page 1, 2  Next
 Post subject: Here weeeeee go!
 Post Posted: Tue Jun 16, 2015 3:02 am
Well I finally took the plunge, after my Hyundai failed it's mod on 2 pages ( :oops: ) I decided I'd buy an MPS 3 MK1 today, so I did! been driving around for 6 hours and can honestly say I'm thrilled to bits.
It's a bit of a fixer upper with bits and bobs needing doing but nothing urgent. Roll on saving for the first mods - thinking headunit/gauges and a butterfly valve.
Oh, I'm Ben, by the way.
 Post subject: Re: Here weeeeee go!
 Post Posted: Tue Jun 16, 2015 11:05 am
:welcome: along :thumbs:
 Post Posted: Tue Jun 16, 2015 1:34 pm
:welcome: Ben.
Butterfly delete you mean?
 Post Posted: Tue Jun 16, 2015 2:35 pm
Hi Ben
:welcome: along to :mpsoc:
 Post Posted: Tue Jun 16, 2015 6:31 pm
Sir-SpamFace wrote:
:welcome: Ben.
Possibly! This is my first turbo car so I'm new to all things FI, but I want the typical chatter noise when lifting off.. BOV instead of butterfly?
 Post Posted: Wed Jun 17, 2015 10:52 am
Ben I think you have some reading to do :thumbs: welcome to :mpsoc: though :)
There are no butterflies involved though.
 Post Posted: Wed Jun 17, 2015 11:00 am
Ah I get what you mean now.
You can't run a BOV on these cars as they require the air to be measured the recirculated back into the system to get the correct amount of air to fuel ratio (AFR's)
Well, saying that, it can be done but is far from cheap. Including the BOV you'd be looking at spending £400+, for the sake of a bit of noise.
There are however adjustable recirc valves that you can get away with that dump a % of air out while allowing enough air to recirc to keep the engine happy. A GFP one for example
 Post Posted: Wed Jun 17, 2015 11:28 am
Thanks for that! Most of my questions will be turbo related in afraid! With that in mind I'll go ahead and skip the bov and jump into upgrading the fuel pump, that seems like the common consensus as a starting point
 Post Posted: Wed Jun 17, 2015 1:34 pm
O another note, does anyone know if this is the cheapest I'll find something like a center triple gauge pod? I've seen a few post in the forums but they're all quite out dated now :/
http://www.total-mps.co.uk/right-hand-d ... 06-09.html
 Post Posted: Thu Jun 18, 2015 10:15 am
you can still get a good wooshing noise from a forge recerc and sri/tip
BNR3,snow stage 2 meth injection :D, 3"HTP induction, HDI GT2 PRO FMIC, jetex cb, ATP LDP, 3bar map sensor,Grimmspeed EBCS Electronic Boost Control Solenoid, forge v2 recerc, autotech HPFP, silicone return hose, silicone radiador hoses, small battery tray, stoptech drillied/slotted discs front and back, painted callipers front and back, wrapped bonnet and wing mirrors, tinted rear windows, custom side mount number plate holder, custom reupholstered seats and door cards, dipped centre console,AEM digital/analogue boost gauge-oil temp/pressure gauges, road angel jem, mio incarr cctv, built in freeview, bluetooth parrot kit, satnav, iPod connectivity, new age auto glow in the dark spider gear nob, polly ARB bushes front/rear,front whiteline strut bace, BC racing colliers, VVT
 Post Posted: Thu Jun 18, 2015 10:46 am
It's HPFP internals you want, not a new pump.
Take this advice on board, stay away from totalmps, turbo pacs, BBRgti, litchfield.
Check out my sig for reasons on total.
 Post Posted: Thu Jun 18, 2015 12:04 pm
What's an sri/tip?
 Post Posted: Thu Jun 18, 2015 2:18 pm
Benbee wrote:
What's an sri/tip?
Short ram intake, turbo inlet pipe
 Post Posted: Thu Jun 18, 2015 2:19 pm
Ah I'm with you now, need to update on my acronyms! I've ordered some prosport gauges yesterday. Just need to source a center dash triple pod if I'm avoiding total MPS but I'll do that this weekend s
 Post Posted: Thu Jun 18, 2015 4:42 pm
IIRC you can get them from states for £30
