Andypack1
Post subject: Hi all Posted: Sat Mar 19, 2016 3:22 pm |
Joined: Sat Mar 19, 2016 3:20 pm Posts: 10 Location: Scottish borders Vehicle: MPS3 mkII
Been thanked: 3 times
Hi all Just joined after picking up a 2010 black 3 MPs this morning
Gouldy
Post subject: Re: Hi all Posted: Sat Mar 19, 2016 11:10 pm |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
Hi and  along to When you get a chance, get some photo's up.
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
Post subject: Re: Hi all Posted: Sun Mar 20, 2016 10:39 am |
 to the club
BanzaiMike
Post subject: Re: Hi all Posted: Sun Mar 20, 2016 11:39 am |
Has thanked: 3 times
Been thanked: 26 times
Hi and welcome to the family, hope you enjoy the car as much as the rest of us
~Divine~Wind~
Post subject: Re: Hi all Posted: Sun Mar 20, 2016 1:00 pm |
Joined: Fri Sep 06, 2013 7:45 pm Posts: 2813 Location: North-East, Newcastle Vehicle: MPS6
Has thanked: 5 times
Been thanked: 136 times
autech
Post subject: Re: Hi all Posted: Mon Mar 21, 2016 6:51 pm |
Joined: Tue Nov 24, 2015 11:37 am Posts: 149 Location: Manchester Vehicle: MPS3 mkII
Has thanked: 21 times
Been thanked: 12 times
Hi there welcome to the boost addiction centre. Take a ticket and wait to be seen by one of our doctors, they are fully trained in mod addiction and helping you empty your "bad mother fucker" wallet.
_________________ Autotech internals // HTP 3" Full Intake // CP-E Top Mount // Stoptech Rotors/Pads // HEL braided lines // Corksport Hood Scoop // Cobb AP v3 // GFB Respons // Bilstein B12 Pro Kit // Whiteline Rarb and links // 4" Custom Tips // CFM 9 Peg Army // VVT done at Young Motors // J-Tuned
BLUNTY
Post subject: Re: Hi all Posted: Mon Mar 21, 2016 7:40 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
