karl22
Post subject: braking issue Posted: Thu Mar 10, 2016 8:49 pm |
Hi I have a Mazda 3 mps Recently Ive had real bad braking issue ONLY from high speed. I get real bad shake on the steering wheel and it's horrendous. I had lower arm rear bushes replaced and two new tyres fitted at the same time and all tracked and balanced. Seemed to had solved the problem for a day or two but it came back and now tonight I have a really bad scoring and screeching noise from the front right wheel which again sometimes comes and goes but its been it's worse tonight. Kind of baffled now as i thought I'd solved the problem but its still here. All help appreciated Thanks Karl
jedi ronin
Post subject: Re: braking issue Posted: Thu Mar 10, 2016 8:55 pm |
Joined: Sat Feb 06, 2010 12:11 pm Posts: 3322 Location: area 51 Vehicle: MPS3 mkI
Has thanked: 268 times
Been thanked: 62 times
Bhp: 2
lbf·ft: 5
uprated discs and pads:thumbs:
_________________ A Mazda man can!!
Post subject: Re: braking issue Posted: Fri Mar 11, 2016 7:04 am |
Sounds like you have a warped disc.
JamesG
Post subject: Re: braking issue Posted: Fri Mar 11, 2016 9:40 am |
Joined: Mon Feb 08, 2010 11:29 pm Posts: 5313 Location: SE28 0EB Vehicle: other
Been thanked: 17 times
Bhp: 175
lbf·ft: 310
Or pad pickup on the disc Or a sticky caliper Or a badly worn pad
_________________ Remember; The most important nut is the one holding the steering wheel
crazyhobo
Post subject: Re: braking issue Posted: Fri Mar 11, 2016 6:37 pm |
Joined: Mon Feb 16, 2015 5:00 pm Posts: 364 Location: South London Vehicle: MPS6
Has thanked: 61 times
Or loose wheel nuts lol
_________________ 2007 6MPS- Power: Autotech HPFP, COBB AP V3, CS 2.5" Intake + TIP, CS BPV, CS TBE, EGR Blockoff
- Handling: JBR 80A Triology Mounts, Stoptech Slotted Discs
- Other: Sure SSP, Sure Anchors, LED Interior/Number Plate/Side lights, Dave Plank Dials, Royal Steering Wheel Retrim
- To be fitted: Mishimoto OCC, FMIC, Blistein B8s, Eibach Springs, Whiteline RARB, CPE & Sure Diff Mounts
