 Post subject: New MPS Owner
 Post Posted: Mon Oct 12, 2015 12:46 pm
Hi :mpsoc:,
Just want to say Hi, as, as from today i am a proud owner of a mk2 MPS in red and already have the bug to do thing to her :lol:
TheLane
 Post subject: Re: New MPS Owner
 Post Posted: Mon Oct 12, 2015 1:02 pm
:welcome: to :mpsoc:
Pics ? :)
 Post Posted: Mon Oct 12, 2015 1:23 pm
Here's pics of the MPS
Image Image
 Post Posted: Mon Oct 12, 2015 1:56 pm
:welcome: to the club :thumbs:
 Post Posted: Mon Oct 12, 2015 3:28 pm
Welcome, now where are the pics?!
 Post Posted: Mon Oct 12, 2015 9:10 pm
Welcome mate
 Post Posted: Tue Oct 13, 2015 8:01 am
lbf·ft: 285
Hi Mark welcome to the group
 Post Posted: Tue Oct 13, 2015 8:13 am
Welcome to :mpsoc: Nice looking Mk2 you have.
Where are you based?
 Post Posted: Tue Oct 13, 2015 9:37 am
Welcome to the forum dude :)
 Post Posted: Tue Oct 13, 2015 10:17 am
:welcome: :mpsoc: Enjoy! :thumbs: :thumbs:
 Post Posted: Tue Oct 13, 2015 11:30 am
I'm based in greater london in Hanworth about 5 minutes from Twickenham Rugby stadium.
 Post Posted: Tue Oct 13, 2015 11:39 am
Nice, I have a feeling there is a Mk2 owner local-ish to you on here.
 Post Posted: Tue Oct 13, 2015 1:43 pm
Bhp: 317
lbf·ft: 326
Welcome to the forum ;)
Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
 Post Posted: Sat Oct 17, 2015 10:21 am
 Post Posted: Sat Oct 17, 2015 4:32 pm
Has thanked: 168 times
Been thanked: 113 times
Hi and :welcome: along to :mpsoc:
Nice motor you have there.
Oh and in the fastest colour!
Most importantly, J Tune!!!!!
