Page 1 of 1 [ 10 posts ]
 Post subject: Introduction
 Post Posted: Wed Jun 03, 2015 5:46 pm
Hi to all,
Just recently joined, I'm Paul and I come from Farnborough in Hampshire. I've recently purchased an MPs 59 reg mk2 (black) " best colour " so I've read by others .Well pleased with it but have plans for a remap in the not to distant future.
 Post subject: Re: Introduction
 Post Posted: Wed Jun 03, 2015 5:52 pm
Have you read up on where to goeth and who to avoid?
You'll want HPFP internals first before a map
 Post Posted: Wed Jun 03, 2015 7:09 pm
:welcome: along :thumbs:
 Post Posted: Wed Jun 03, 2015 7:14 pm
Has thanked: 168 times
Been thanked: 113 times
:welcome: along to :mpsoc:
Most importantly, J Tune!!!!!
 Post Posted: Thu Jun 04, 2015 3:01 pm
Hi and welcome along.
We have a nice beginners guide to the cars and how best to safely mod them, hope you enjoy your purchase
 Post Posted: Thu Jun 04, 2015 9:13 pm
 Post Posted: Sat Jun 06, 2015 10:34 pm
Good colour choice :-). Welcome to the forum.
 Post Posted: Sun Jun 07, 2015 7:37 am
:welcome: :mpsoc: :wwp:
 Post Posted: Sun Jun 07, 2015 12:31 pm
Welcome to the forum!
 Post Posted: Mon Jun 08, 2015 5:50 pm
Hi ,just a thank you for the welcomes received ,l look forward to getting to use the forum and the very useful information available.
Paul
