alex86
Post subject: 6 Mps just bought! Posted: Mon Apr 27, 2015 4:29 am |
Joined: Tue Apr 21, 2015 7:08 pm Posts: 3 Location: Nottingham Vehicle: MPS6
Hello all. I have just purchased my first mazda and I must say I am impressed. I am a massive honda enthusiast and still own my 99 mb6 vtis, just couldnt bring myself to sell it. Anyway on to the mazda. 2007 56 plate 6 mps totally standard (for now) 57,000 miles, timing chain and vvt replaced at 54k. Near immaculate and I got it for 4400 which considering all the others I have seen I was very pleased with. So far not a bad word to say about it but still getting used to it. The only thing that has annoyed my is one of the sliding tabs on the roof runners has come off to which I want to replace immediately but I am unsure what they are actually called. Any help would be appreciated. So what next for the mps. Well as mentioned earlier I am keeping my honda as only 500 were ever built there just aren't many around but with that comes a cost courtesy of the other half to which I quote "if anything goes on that new car that shouldn't be there you are selling the honda" she didn't say much after picking herself up off the floor. That last bit was a joke please don't show her this. So the battle goes on. Pictures going up soon and if anyone can help me with a name or part number for the roof tabs that would be awesome. I assume they are covers for where a roof rack would go but why the F you'd put a roof rack on that is beyond me. Thanks for reading.
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 7:33 am |
RM BIK |
Hello and a warm   Fill in your profile details too if you don't mind ?  Also.... http://pages.ebay.com/link/?nav=item.vi ... 1554795601
R4SH
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 8:02 am |
Joined: Sun Jul 27, 2014 11:34 pm Posts: 202 Location: London Vehicle: looking to buy
Has thanked: 9 times
Been thanked: 9 times
 to the forum buddy. Yes the tiny black covers seem to be a recurring occurrence, I just ordered a couple of replacements. Either they fall off or they being nicked!?
Jim
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 8:22 am |
Founder |
Been thanked: 55 times
Welcome along to  I like MB6's
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 8:25 am |
MPSOC Member |
 along
Gav1888
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 8:48 am |
Has thanked: 56 times
Been thanked: 28 times
BLUNTY
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 10:58 am |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
Machine
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 11:50 am |
Senior |
Joined: Wed May 15, 2013 9:14 am Posts: 537 Location: Weaverham, Cheshire Vehicle: MPS6
Has thanked: 23 times
Been thanked: 21 times
Welcome, were about are you based?
The black covers are easy to put on "backwards", and they aren't very stable that way so could come loose. I had to compare vs the others to get it right.
_________________ Stock 6 MPS : because it's fine as it is!
JB21
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 12:04 pm |
Senior |
Joined: Tue Jul 01, 2014 7:15 am Posts: 3053 Vehicle: other
Has thanked: 53 times
Been thanked: 115 times
Welcome along mate, I also came from the Honda scene (ep3). Loved the Honda and still miss it but would miss the brute force and AWD of the MPS more. I honestly thought the standard 6 was shite, so got modding ASAP (within a week) and have never looked back.
_________________ Mondeo ST155: Daily commuter
BMW i3 ReX: Evening & weekend town car
Renault Clio 182 FF: Track toy
Gouldy
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 1:06 pm |
Senior |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
 along to My 6 is missing two of those things so just ordered a set of ebay. Cheers Sir-SpamFace for the link.
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
alex86
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 3:38 pm |
Cheers sir spam most useful. And cheers gaz I just ordered some without reading the rest of the comments but its appreciated all the same.
JB I'm more of a b series honda guy just love the simplicity and the way the b series revs. Going to completely strip my C4 engine and up the compression just a little project.
Thanks for all the welcomes gents.
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 5:22 pm |
Global Moderator |
Hi and  to the club
alex86
Post subject: Re: 6 Mps just bought! Posted: Mon Apr 27, 2015 7:23 pm |
To
Kenny
Post subject: Re: 6 Mps just bought! Posted: Tue Apr 28, 2015 4:05 pm |
Senior |
Been thanked: 11 times
Post subject: Re: 6 Mps just bought! Posted: Wed Apr 29, 2015 5:54 am |
Senior |
Hello and welcome
