lippybyrightz
Post subject: Yooo Hooo Posted: Sun Apr 26, 2015 9:57 am |
Joined: Thu Apr 23, 2015 7:23 pm Posts: 41 Location: Bolton Vehicle: MPS3 mkII
Alreet, I'm new to the forum (using tapatalk for now) I'm Matt, or "Lippy" to some I own a 2010 plate Red Mazda 3 MPS MK2. Bought her last year from one of the members on here.  She's a beaut, few niggles here and there but what car doesn't. Gives her character Will start some basic prodding and modding later on this year so i'll post a bit more often then so just a hello for now ! That's all for now folks
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 11:13 am |
BanzaiMike
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 1:46 pm |
Has thanked: 3 times
Been thanked: 26 times
Hi and welcome to the family
TheAngryDog
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 1:48 pm |
Joined: Sun Feb 08, 2015 3:24 pm Posts: 446 Location: Buckinghamshire
Has thanked: 74 times
Been thanked: 13 times
Welcome to the forum
_________________ Nothing!
Gouldy
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 3:48 pm |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
 along to Nice looking motor. Look forward to reading about your progress.
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
lippybyrightz
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 4:21 pm |
I'm looking forward to progress too ha ! 'Twill be slow and strung out unfortunately, money's all tied up in my house being rennovated atm.. got to have nice digs so the ball and chain can't complain when Kami gets all the attention [GRINNING FACE WITH SMILING EYES]
IOM 6MPS
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 4:22 pm |
Joined: Sat Oct 27, 2012 8:13 pm Posts: 260 Location: Isle of Man Vehicle: MPS6
Has thanked: 14 times
Been thanked: 18 times
Very shiney
_________________ Tuned with Alcon 6 pot Brake Calipers with 365mm Discs, Cosmis S1 18x9.5 inch alloys and 265/35/18 tyres Treadstone Front Mount Intercooler Kit. TR1035 core, clamps with piping, and a crash bar! CorkSport Power Series II SRI, Blitz Bypass Valve Cobra Single Exit Exhaust and Decat CorkSport Upper Control Arms adjustability from -0.2 degrees to -2.0 degrees for added and improved control, spherical bearings replace the soft rubber bushings used in OEM and arms for more precise suspension settings Corksport Rear Camber Arms +/- 5 degrees of camber adjustment AWR Engine Mount Set Turbine Tech forward Differential Mount Brace CPE xFlex™ Rear Differential Mount Whiteline Upgraded Anti Roll Bar Bilstein B12 Pro Suspesion Kit RX8 R3 Recaro's, Retrimmed RX8 R3 Steering wheel in Leather and Alcantara with Red stitching. James Barone Racing - Short Shift Kit and JBR Heavy Gear Knob. Evo X rear Spoiler LED rear lights VersaTuner map
Gav1888
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 4:45 pm |
Has thanked: 56 times
Been thanked: 28 times
 to Best and fastest colour
Infuzed
Post subject: Re: Yooo Hooo Posted: Sun Apr 26, 2015 6:51 pm |
Joined: Tue May 20, 2014 11:36 pm Posts: 688 Location: Berkshire/Buckinghamshire Vehicle: MPS3 mkI aero
Has thanked: 16 times
Been thanked: 16 times
lbf·ft: 340
Welcome, looks mint! ;)
_________________ Current Mods :: K&N Typhoon SRI :: Corksport TIP :: Powerflow 2nd Decat :: Forge V1 BPV :: ASI TMIC :: Cobb 3-Port :: VibraTechnics REM :: Koni STR.Ts (Rear) :: Rainsport 3s :: (J-Tune In Progress)
Selling up :( ::
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 1:59 am |
Hi and  to the club
ShaunyG
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 6:10 am |
cfcjre
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 11:51 am |
Joined: Tue Sep 16, 2014 3:21 pm Posts: 307 Location: Newcastle-under-Lyme Vehicle: MPS3 mkI aero
Bhp: 294
lbf·ft: 324
_________________ true red mk1 3MPS, Hypertech tune, Corksport SRI+TIP, Resonator and 2nd Cat removed, Powerflow custom exhaust, Turbosmart BPV, J-Speed short shift plate, Lowered 40mm H&R springs, Gloss black RX-8 alloys, Mazdaspeed stubby carbon Ariel, XCarlink.
BLUNTY
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 12:06 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
lippybyrightz
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 5:42 pm |
Thanks for the warm welcome
james4133
Post subject: Re: Yooo Hooo Posted: Mon Apr 27, 2015 7:49 pm |
Joined: Fri Aug 03, 2012 4:42 pm Posts: 75 Location: Bolton Vehicle: MPS3 mkII
Hello mat looked clean the other day when I seen you
