 Post subject: MPS is coming!!!
 Post Posted: Thu Feb 19, 2015 9:31 pm
Evening All,
I'm new to the site, but glad i've found it as i'm looking to buy a mk2 mazda 3 mps.
Any tips? and hello all :panic:
 Post subject: Re: MPS is coming!!!
 Post Posted: Thu Feb 19, 2015 10:06 pm
Welcome to the :mpsoc:
Check out the buyers guide in the Welcome Lounge, has a lot of the information you need when hunting for one :)
 Post Posted: Fri Feb 20, 2015 12:24 am
 Post Posted: Fri Feb 20, 2015 12:36 am
If your adamant you'll be getting one, paid membership is the best thing you'll ever buy for your mps :thumbs:
 Post Posted: Fri Feb 20, 2015 6:59 am
 Post Posted: Fri Feb 20, 2015 11:03 am
:welcome: along :thumbs:
 Post Posted: Fri Feb 20, 2015 12:19 pm
Welcome
check normal car type stuff , strange noises from the left side of the engine ( as your looking at it ) and a smokescreen of white smoke from the exhaust.
 Post Posted: Fri Feb 20, 2015 12:40 pm
:welcome: to :mpsoc: good luck with your find :)
 Post Posted: Fri Feb 20, 2015 5:35 pm
lbf·ft: 322
You have come to the right place.
Welcome to MPSOC. :-)
 Post Posted: Thu Apr 02, 2015 3:28 pm
Finally after a lot of faffing about, i finally have my MPS, and i could'nt be happier.
Pics to follow soon. :mpsoc:
 Post Posted: Tue Jun 02, 2015 12:25 pm
 Post Posted: Tue Jun 02, 2015 9:41 pm
Hi and Welcome to MPSOC
 Post Posted: Wed Jun 03, 2015 1:47 am
Welcome to the forum
 Post Posted: Sun Jun 07, 2015 12:41 pm
 Post Posted: Sun Jun 07, 2015 2:55 pm
Has thanked: 168 times
Been thanked: 113 times
Hi and :welcome: along to :mpsoc:
:wwp:
Most importantly, J Tune!!!!!
