Page 2 of 2 [ 23 posts ] Go to page Previous  1, 2
 Post subject: Re: New member
 Post Posted: Fri Nov 07, 2014 11:01 am
Hi and welcome to the asylum :mpsoc:
 Post Posted: Sat Nov 08, 2014 2:21 pm
:welcome: to :mpsoc:!!
Get a MK2, excellent car! Way better than the ST, VXR, GTI, WRX etc
I got some mods...
 Post Posted: Sat Nov 08, 2014 3:22 pm
Welcome to the :mpsoc: forum.
Another vote here for a Mk2, I'm not biased or anything :lol:
 Post Posted: Sat Nov 08, 2014 3:24 pm
Welcome ....I'm not biased either so I would go with mk2 as well
 Post Posted: Sat Nov 08, 2014 3:32 pm
Welcome along. Just take your time and buy a good one. Search on here about issues etc before buying.
 Post Posted: Sat Nov 08, 2014 3:55 pm
:welcome: to the Madhouse :mpsoc: MK1 is faster! :thumbs:
 Post Posted: Mon Nov 10, 2014 5:18 am
Oh really?
The Mk1 feels faster in the way it delivers the delivers the power and the noise it makes.
The Mk2 is a little too quiet stock, but a full decat soon sorts that.
I got some mods...
 Post Posted: Thu Nov 27, 2014 10:56 pm
