 Post subject: From Kawasaki to MPS
 Post Posted: Mon Sep 29, 2014 5:28 pm
Hi all :)
I've had to part with my motorbike for something more "sensible" so it was obviously going to be a Mazda 3 (didn't tell her it was an MPS though ;) ).
It was a trade in at work with a couple of months ago with 50k on the clock, full Mazda history and was driven pretty badly by a the previous owner (kerbed wheels, little dents and scratches here and there and the smell of dog inside!). Got it nice and cheap though so could see the potential in it.
Don't have any before pics unfortunately but this is how she looks now:
I've noticed there's a bit of a rattle for a split second on cold startup so will have to head over to technical I think. Or is that just normal for one of these?
Cheers :D
 Post subject: Re: From Kawasaki to MPS
 Post Posted: Mon Sep 29, 2014 6:12 pm
 Post Posted: Mon Sep 29, 2014 6:57 pm
Probably just the timing chain before the oil pressure activates the tensioner. Restart it after start up. There should be no noise. Nevertheless, get your people to check the vvt just in case as it is an expensive repair.
 Post Posted: Mon Sep 29, 2014 7:58 pm
Hi mate mine does the same only on cold startup . But fine after that. All checked out been told all is good. Hope this helps
 Post Posted: Mon Sep 29, 2014 8:15 pm
Welcome to the forum.
If its any consolation, my mk2 makes a slight rattle for a split second or so on a cold start, but if its warm or turned off and then back on again, it doesn't do it. It's probably like foxy said, timing chain before the oil pressure activates the tensioner :thumbs:
 Post Posted: Mon Sep 29, 2014 9:33 pm
Cheers guys, I've posted in the technical section. I imagine it's fine but worth concern I think.
 Post Posted: Mon Sep 29, 2014 11:57 pm
:welcome: to the forum!
 Post Posted: Tue Sep 30, 2014 9:39 am
Welcome to the forum mate looking good :)
 Post Posted: Tue Sep 30, 2014 3:36 pm
:welcome: ......best colour mate
 Post Posted: Tue Sep 30, 2014 4:54 pm
Bhp: 148
lbf·ft: 138
Hi, Car looks great, always worth a bit of effort. Welcome to the Forum.
You were't tempted to get one of these then.
http://www.motorcyclenews.com/mcn/news/ ... -ninja-h2/
Show an MPS a clean pair of wheels, or a Veyron Supersport for that matter.
 Post Posted: Tue Sep 30, 2014 5:00 pm
Saw that bike earlier on Pistonheads, it's officially nuts! : eek2 :
 Post Posted: Wed Oct 01, 2014 11:32 am
Absolutely stunning machine! Maybe when they drop in price a little ;)
 Post Posted: Tue Oct 14, 2014 7:53 am
Bhp: 320
lbf·ft: 340
Welcome mate
Car looks lovely
2009 mazda 3 mps face lift,HTP 3' intake,hpfp,HDI fmic,GFB dump valve,sure red return hose,Down pipe,sure second decat,jetex cat back,BNR turbo,Cobb v3,3 Bar map sensor and harness,isc adjustable coilovers,JBR short shifter,performance brakes 345mm 6 pot big brake kit with braided lines and uprated fast road/track pads,Enkei m52 alloys,Mazdaspeed stubby aerial,mazdaspeed valve caps,mazdaspeed oil filer cap,cobb gear knob,solid shifter bushes,oil filter spin on kit,centre triple gauge pod,sure rem,ice white fogs and side lights,20mm spacers all round,arches modified,G9 door lip splitter,rear spoiler extension,custom yellow mazdaspeed domed badges ,mapped by justin Heath and Bernie's blowers built my bnr hybrid.
Fastest quarter mile so far on my first run 13.0@112.6mph going for 12's now
Previous fast cars,
Starlet GT
Subaru Impreza WRX STI type RA V limited
Supercharged mk6 fiesta ST
Evo 9 GT
Silvia S15 Spec-R
Now the mps
 Post Posted: Sun Oct 19, 2014 10:01 pm
 Post Posted: Mon Oct 20, 2014 12:54 am
Users browsing this forum: No registered users and 21 guests
