shep
Post subject: Hey Posted: Thu May 15, 2014 7:22 pm |
I don't actually own an MPS 'yet' but I've been browsing Autotrader like crazy. Just a little unsure on what I want exactly. I like the look of all the MPS but would it be worth splashing that extra bit of cash to get the new model? The facelift version with the twin exhausts etc. What actually are the differences between the two? Cheers Lee
JamesG
Post subject: Re: Hey Posted: Thu May 15, 2014 7:53 pm |
Joined: Mon Feb 08, 2010 11:29 pm Posts: 5313 Location: SE28 0EB Vehicle: other
Been thanked: 17 times
Bhp: 175
lbf·ft: 310
There are more or less 3 versions of the 3 MPS. All have a 256bhp 2.3 DISI engine. You have: Mk1 Mk1 Aero - comes with lowered Eiback springs and dinky wing mirrors. There is a facelift too around 2008-2009 which has probably the nicest interior of any 3 MPS Mk2 from late 2009 onwards has a new chassis and some changes to the engine. High points are stiffer chassis, better damping, wider wheels (7.5j vs 7j on the mk1) and 225/40/18 tyres vs 215/45/18 on the mk1, stiffer springs, more kit, improved turbo seals, different ECU and a lot more kit. Mk1 & Aero will cost less. mk2 is a better drive with more kit but costs more. Some people prefer the looks of the mk1, some the mk2. All can be modified to the nth degree depending on your budget. Mk1 is more expensive on VED, but considering other costs, £200 per year should not sway your decision. What are you after? What kind of driving do you do? Do you like drag or the twisties? Do you do lots of miles? Are you looking to mod & if so what have you done before and what could you be persuaded into? To give you a poke, the MPS with a few well chosen mods will see off any sub 40k hot hatch and many mega powerful saloons and performance cars.
_________________ Remember; The most important nut is the one holding the steering wheel
grandchamp2k7
Post subject: Re: Hey Posted: Thu May 15, 2014 8:58 pm |
Joined: Sat Feb 06, 2010 5:59 pm Posts: 6153 Location: stirling,central scotland
Been thanked: 16 times
Hello,welcome to the forum. A good summary from james.
_________________ ?
Kenny
Post subject: Re: Hey Posted: Thu May 15, 2014 10:15 pm |
Been thanked: 11 times
Welcome to the forum mate
Benz
Post subject: Re: Hey Posted: Thu May 15, 2014 10:31 pm |
Joined: Thu Apr 11, 2013 1:24 pm Posts: 947 Location: Stirling, Scotland Vehicle: other
 to the forum! I think JamesG has it covered there
Post subject: Re: Hey Posted: Fri May 16, 2014 6:07 am |
ShaunyG
Post subject: Re: Hey Posted: Fri May 16, 2014 6:57 am |
Been thanked: 13 times
Welcome to the forum and good summary there James
Post subject: Re: Hey Posted: Fri May 16, 2014 8:58 am |
James #nailedit
~Divine~Wind~
Post subject: Re: Hey Posted: Fri May 16, 2014 9:43 am |
Joined: Fri Sep 06, 2013 7:45 pm Posts: 2813 Location: North-East, Newcastle Vehicle: MPS6
Has thanked: 5 times
Been thanked: 136 times
Mk1 / Mk2 The obvious one would be the Tax difference to me. The Mk2 has a slightly different engine for the turbo side of things too afaik Agree that the mk1 facelift is the best interior
_________________ Mazda 6 MPSMazda 6 MPSMazda 6 MPSHelpful threads http://tinyurl.com/kjykgbdEdge 2016 Groupbuy #2 - viewtopic.php?f=84&t=24079
sternritter
Post subject: Re: Hey Posted: Fri May 16, 2014 10:08 am |
Has thanked: 7 times
Been thanked: 10 times
~Divine~Wind~ wrote: Mk1 / Mk2 The obvious one would be the Tax difference to me. The Mk2 has a slightly different engine for the turbo side of things too afaik Agree that the mk1 facelift is the best interior  2010+ MK2s have upgraded turbo seals All Mk2s "apparently" have upgraded vvt mk2s have a faster reacting ECU that can detect knock and adjust faster than a F15 on reheat Mk2s have the extra toys Mk2s look infinitely better if you actually want to find your car at asda .
~Divine~Wind~
Post subject: Re: Hey Posted: Fri May 16, 2014 10:12 am |
I went from a silver focus to a black ibiza both were a right mess about finding in a car park haha. I did however like the Beep from the ibiza when you unlocked it, that came in handy many a time :p
Big red 6 aint hard to spot tho :p
Post subject: Re: Hey Posted: Fri May 16, 2014 10:45 am |
Just remember where you parked it....derrr
DaveEdin
Post subject: Re: Hey Posted: Fri May 16, 2014 12:14 pm |
Joined: Sun Jul 29, 2012 12:35 pm Posts: 1143 Location: Edinburgh, Scotland Vehicle: MPS6
Has thanked: 24 times
Been thanked: 43 times
Bhp: 280
lbf·ft: 295
JamesG wrote: There are more or less 3 versions of the 3 MPS. All have a 256bhp 2.3 DISI engine. You have: Mk1 Mk1 Aero - comes with lowered Eiback springs and dinky wing mirrors. There is a facelift too around 2008-2009 which has probably the nicest interior of any 3 MPS Mk2 from late 2009 onwards has a new chassis and some changes to the engine. High points are stiffer chassis, better damping, wider wheels (7.5j vs 7j on the mk1) and 225/40/18 tyres vs 215/45/18 on the mk1, stiffer springs, more kit, improved turbo seals, different ECU and a lot more kit. Mk1 & Aero will cost less. mk2 is a better drive with more kit but costs more. Some people prefer the looks of the mk1, some the mk2. All can be modified to the nth degree depending on your budget. Mk1 is more expensive on VED, but considering other costs, £200 per year should not sway your decision. What are you after? What kind of driving do you do? Do you like drag or the twisties? Do you do lots of miles? Are you looking to mod & if so what have you done before and what could you be persuaded into? To give you a poke, the MPS with a few well chosen mods will see off any sub 40k hot hatch and many mega powerful saloons and performance cars.  For clarity.... there is a 4th version, called the 6 MPS... It's a saloon, naturally it's better than the various 3 hatchbacks and has AWD as well. [pokes James for not mentioning it - OP only implied that he was after a 3, didn't actually specifically say  ]
~Divine~Wind~
Post subject: Re: Hey Posted: Fri May 16, 2014 1:21 pm |
richie3mps wrote: Just remember where you parked it....derrr  too much debauchery as a youngster, brain like a sieve :p DaveEdin wrote: JamesG wrote: There are more or less 3 versions of the 3 MPS. All have a 256bhp 2.3 DISI engine. You have: Mk1 Mk1 Aero - comes with lowered Eiback springs and dinky wing mirrors. There is a facelift too around 2008-2009 which has probably the nicest interior of any 3 MPS Mk2 from late 2009 onwards has a new chassis and some changes to the engine. High points are stiffer chassis, better damping, wider wheels (7.5j vs 7j on the mk1) and 225/40/18 tyres vs 215/45/18 on the mk1, stiffer springs, more kit, improved turbo seals, different ECU and a lot more kit. Mk1 & Aero will cost less. mk2 is a better drive with more kit but costs more. Some people prefer the looks of the mk1, some the mk2. All can be modified to the nth degree depending on your budget. Mk1 is more expensive on VED, but considering other costs, £200 per year should not sway your decision. What are you after? What kind of driving do you do? Do you like drag or the twisties? Do you do lots of miles? Are you looking to mod & if so what have you done before and what could you be persuaded into? To give you a poke, the MPS with a few well chosen mods will see off any sub 40k hot hatch and many mega powerful saloons and performance cars.  For clarity.... there is a 4th version, called the 6 MPS... It's a saloon, naturally it's better than the various 3 hatchbacks and has AWD as well. [pokes James for not mentioning it - OP only implied that he was after a 3, didn't actually specifically say  ] Bigger... Better... Faster... RED!!! ;)
Benz
Post subject: Re: Hey Posted: Fri May 16, 2014 10:13 pm |
~Divine~Wind~ wrote: For clarity.... there is a 4th version, called the 6 MPS... It's a saloon, naturally it's better than the various 3 hatchbacks and has AWD as well. [pokes James for not mentioning it - OP only implied that he was after a 3, didn't actually specifically say  ] Bigger...???? Bigger? Is there more leg room in the back seat in the 6 than there is in the 3? i bet the 3 can carry more luggage etc with rear seats folded Better...???  maybe the AWD Faster... RED!!! [/quote]
