Page 1 of 2 [ 23 posts ] Go to page 1, 2  Next
 Post subject: Gday From Australia!
 Post Posted: Sat Oct 26, 2013 10:08 am
Bhp: 513
lbf·ft: 531
Hello there fellow MPS owners from the mother land.
My name is Ray, I am 24 years of age, currently in my 6th year of studying Dentistry, I own and run a small business which is normally centred around anything to do with electronics/ AV/ custom PCB's/ etc etc and @Spamface has been kind enough to organise a group buy for my AUX leads for the MPS 6.
I also own a MPS 6 which i have worked and completed all mods on myself and i've been invited by @Spamface to introduce myself and my car from the land downunder! :)
So here are the mods:
ENGINE
WEISCO FORGED 0.020" OVERSIZED PISTONS
CPe RODSCOMETIC HEAD GASKET
ARP HEAD STUDS
3.5 BAR MAP SENSOR
SURE THERMAL INSULATING GASKETS
PERFORMANCE AUTOMOTIVE PCV OIL CATCH CAN V1 WITH CHECK VALVE
CPe HIGH PRESSURE FUEL PUMP
CPe INJECTOR SEALS
DENZO ITV22 1 STEP COLDER PLUGS
PERM PCV PLATE
TURBO & PIPING
GARRET GTX3071R BOLT ON TURBO (Exhaust housing ceramic coated)
CPe EXHAUST MANIFOLD (Ceramic Coated)
TIAL 38MM EXTERNAL WASTEGATE
HTP FULL 4" INTAKE
CUSTOM INLINE 6" AIR FILTER
CUSTOM 3" DOWNPIPE (WESTERN MUFFLERS)
CUSTOM HIFLOW CAT BACK DUAL 3" EXHAUST (WESTERN MUFFLERS)
PERRIN 3-PORT ELECTRONIC BOOST CONTROL SOLENOID
TURBOSMART DUAL PORT BLOW OFF VALVE (set to full recirculate)
COOLING
ETS 3.25" TOP MOUNT INTERCOOLER
DEVILSOWN DVC-30 METHANOL/ WATER INJECTION KIT (CURRENTLY USING DO10 NOZZLE & 50% METHANOL)
EGR DELETE
COOLANT BYPASS
DRIVELINE
SPEC STAGE 3+ CLUTCH
FIDANZA LIGHTWEIGHT SINGLE MASS FLYWHEEL
SURE DREADNAUGHT REAR DIFFERENTIAL BRACE
SURE JUGGERNAUT REAR DIFFERENTIAL FRONT MOUNT
CPe REAR ENGINE MOUNT
AWR DRIVER SIDE MOUNT
JBR SHORT SHIFTER + METAL SHIFTER BUSHINGS
PEDDERS SUPERLOW SPRINGS
OTHER
SWOOSH ELECTRONIC STEPPER BOOST GAUGE
COBB ACCESS PORT (LC@42500RPM/ FFS@5250RPM)
FWD SWTICH
LOW METH FLASHING LED INDICATOR
GPS DVD BLUETOOTH IPOD ALL IN ONE UNIT
CUSTOM MADE BOSE SUB PREAMP
MPS 3 GEN 2 WHEELS
MPS FLOOR MATTS
MAZDA AUTOMATIC HEADLIGHT KIT
FULL LED CONVERSION (Interior and exterior)
REVERSE SENSORS
REVERSE CAMERA
SECOND POWER SOCKET IN CENTRE ARM CONSOLE
BONNET DECALS
RED BRAKE CALLIPERS
BLACKOUT SIDE REFLECTORS C
CAR-LED REAR TAIL LIGHTS
6000K D2S HID BULBS
MUGEN WINDOW VISORS
_____________________________________________________________________________________________
Now i understand that you guys talk BHP, and i've been informed that you guys estimate an average of 18% drivetrain loss in the MPS 6, so for the sake of comparison i've attached a VD containing my latest log (with 2 people in the car) at CF: 1.29 to reflect BHP (assuming 18% drivetrain loss).
My best 60-100mph was 3.93s (was quite a cold night).
I self tuned my MPS for reasons similar to what Justin Heath has, and have since been been offering etuning through my buisness, and quite a few AUS guys have jumped on board for a tune and so far showing some great results! (see results page, however they are all in wkW so might look strange if not use to looking at different units)
Here are some extra pics :)
GTX3071 + CPe Exhaust Mani Ceramic Coated
Meth tank (stock air resonator) with pump mounted within
Low meth flashing indicator LED
Tapped and fitted DO10 nozzle into intercooler cold pipe near the throttle body entrance[/]
Image[/URL]
[b]RED On - Off switch for whole kit (right) + FWD switch (left)
My next stage is about to commence, i'm about to tear apart a second motor i got my hands on recently and rebuild with high compression pistons for more low end love as well as more all round power which should make it even more fun! especially considering this is my daily driver and all! :D
Looking forward to my stay here and will try to continue to update this thread as things happen!
That is all!
 Post subject: Re: Gday From Australia!
 Post Posted: Sat Oct 26, 2013 10:15 am
:welcome: ray
Excellent write up. Very jealous of your setup. MONSTER!!
 Post Posted: Sat Oct 26, 2013 10:17 am
:welcome: Ray, nice build :thumbs:
 Post Posted: Sat Oct 26, 2013 10:21 am
Ignore the WHP on the graph guys, he's worked it out to show bhp. :thumbs:
 Post Posted: Sat Oct 26, 2013 10:25 am
Welcome mate and very very nice specced car
 Post Posted: Sat Oct 26, 2013 11:04 am
WOW! thats some serious HP!!
Welcome along mate, I am jealous as hell!
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
De-Tuned!!
Mods: Driver!!, Forge BOV, Banjo Bolt, Corksport REM, Good Year Eagle F1s, HIDs, Bonnet Decalsg
Mods Removed: COBB v2, TMPS Downpipe, Corksport Stage 2 Intake, HPFP Internals, Stratified BCS
Sound: Hertz Deici Components, Earthquake Thrust 500 amp, 12" Earthquake Magma sub in a custom box @32hz, 2awg cabling
 Post Posted: Sat Oct 26, 2013 11:05 am
Hi Ray very nice car. monster.
 Post Posted: Sat Oct 26, 2013 11:20 am
Hello and welcome. :)
 Post Posted: Sat Oct 26, 2013 11:55 am
What a beast .I heard its impossible to have a fast car down there .You get fines for going 3kmh over the limit .Madness
 Post Posted: Sat Oct 26, 2013 11:57 am
Don't speed then, just get to the speed damn quick ha
 Post Posted: Sat Oct 26, 2013 11:59 am
There limits are lower than ours I'm led to believe its also state dependant like USA .however with 500bhp your getting there mad quick .
 Post Posted: Sat Oct 26, 2013 12:38 pm
Welcome to the forum mate! Looks like its a bit of a machine :thumbs:
 Post Posted: Sat Oct 26, 2013 1:09 pm
I love this....
 Post Posted: Sat Oct 26, 2013 1:19 pm
Bhp: 513
lbf·ft: 531
Thanks guys!
yeah our speed laws are crazy strict, but always fun on private roads and tracks ;)
@SpamFace; impressed that you found a pic of my head unit :P its one of those Chinese no name brand ones, had to do a bit of modification to the wiring to get it to work with the bose amp but it works pretty well!
 Post Posted: Sat Oct 26, 2013 1:31 pm
Want the nav system. Cool motor if you need some advice on modding I'm your man but I'd start with hpfp with that lot. :lol: :mpsoc: :welcome: :thumbs:
