Page 1 of 2 [ 18 posts ] Go to page 1, 2  Next
 Post subject: 3 mps dump valve
 Post Posted: Mon Feb 27, 2012 7:45 pm
Bhp: 3
hey guys,
just picked my 2010 3 MPS very pleased with it!! proper gti muncher! but not as much engine/ turbo noise as i was expecting. Is it recommended to fit a dump valve and if so will give any more power? or cause any strain on engine/ cause any faults ?
Gone but not forgotten mk2 MPS
New car Focus ST estate
 Post subject: Re: 3 mps dump valve
 Post Posted: Mon Feb 27, 2012 7:51 pm
Its recommended you fit a Recirc Valve, such as the Forge BPV, or Turbosmart. Forge is the most popular choice on here.
Oh and :welcome:
 Post Posted: Mon Feb 27, 2012 7:58 pm
Get a Turbosmart :ppp:
Get your second cat removed and it will sound good! Just ask Ross :thumbs:
 Post Posted: Mon Feb 27, 2012 8:02 pm
Yup as Ross has said, re-circ!
I got my second cat removed and sounds much better, some have had a resonator removed also to make it a little better :thumbs:
 Post Posted: Mon Feb 27, 2012 8:16 pm
On the topic of the 2nd cat, the MKII 3 MPS exhaust is a bit different to the MKI, and i remember a member on here got his 2nd cat taken out of his MKII and didnt experience much change in sound.
 Post Posted: Mon Feb 27, 2012 8:25 pm
I didn't realise he had a MkII... Good call Ross :oops:
 Post Posted: Mon Feb 27, 2012 8:32 pm
You'll still need an intake to get the noises,well at the desired volume anyway.The dv won't be that noticeable and no turbo noises with just a dv.
 Post Posted: Tue Feb 28, 2012 7:18 am
does anyone fancy making a guide on which dump valve /recirc are best and how each sound/affect performance? :D
I'm picking up my 3mps today hopefully and I too am looking for more of a tshhhhhhhhhh :)
 Post Posted: Tue Feb 28, 2012 8:46 am
i have a k&n typhoon and forge recirc and it gets plenty of suck and can hear it recirck into the intake
 Post Posted: Tue Feb 28, 2012 8:51 am
Found a video of the turbosmart.. that sounds pretty daaaarn good.
Along with a CPE 3" turbo back exhaust.. mean.
 Post Posted: Tue Feb 28, 2012 2:20 pm
Bhp: 320
You wont gain any power with an uprated Blow off valve, the only benefits are it wont leak boost, and you should get less turbo lag when changing up a gear whilst flooring it.
 Post Posted: Tue Feb 28, 2012 2:52 pm
As already said you need the intake to hear the blow off valve :thumbs:
 Post Posted: Fri Jun 28, 2013 4:17 pm
My forge dump valve won't work just fitted in on my mps and have tryed all 3 springs yellow blue red now has red in and nothin at all please help !!!
 Post Posted: Sat Jul 06, 2013 7:09 am
Bhp: 288
lbf·ft: 298
What do u mean exactly that it won't work? If its only the dv you changed it will be a very slight noise from it. As said before you need rid of the airbox and replace it with Sri (short ram intake)
 Post Posted: Sat Jul 06, 2013 7:50 am
And tip (turbo inlet pipe) :thumbs:
