Page 1 of 1 [ 5 posts ]
 Post subject: braking issue
 Post Posted: Thu Mar 10, 2016 8:49 pm
Hi I have a Mazda 3 mps
Recently Ive had real bad braking issue ONLY from high speed. I get real bad shake on the steering wheel and it's horrendous. I had lower arm rear bushes replaced and two new tyres fitted at the same time and all tracked and balanced. Seemed to had solved the problem for a day or two but it came back and now tonight I have a really bad scoring and screeching noise from the front right wheel which again sometimes comes and goes but its been it's worse tonight. Kind of baffled now as i thought I'd solved the problem but its still here. All help appreciated
Thanks Karl
 Post subject: Re: braking issue
 Post Posted: Thu Mar 10, 2016 8:55 pm
Has thanked: 268 times
Been thanked: 62 times
Bhp: 2
lbf·ft: 5
uprated discs and pads:thumbs:
A Mazda man can!!
 Post Posted: Fri Mar 11, 2016 7:04 am
Sounds like you have a warped disc.
 Post Posted: Fri Mar 11, 2016 9:40 am
Or pad pickup on the disc
Or a sticky caliper
Or a badly worn pad
 Post Posted: Fri Mar 11, 2016 6:37 pm
Has thanked: 61 times
Or loose wheel nuts lol
2007 6MPS
  • Power: Autotech HPFP, COBB AP V3, CS 2.5" Intake + TIP, CS BPV, CS TBE, EGR Blockoff
  • Handling: JBR 80A Triology Mounts, Stoptech Slotted Discs
  • Other: Sure SSP, Sure Anchors, LED Interior/Number Plate/Side lights, Dave Plank Dials, Royal Steering Wheel Retrim
  • To be fitted: Mishimoto OCC, FMIC, Blistein B8s, Eibach Springs, Whiteline RARB, CPE & Sure Diff Mounts
