Author |
karl22
Post subject: bnr3 setup and help Posted: Wed Mar 09, 2016 3:55 pm |
Non Member |
Hi new to the forum after some advice I've just purchased a full bnr3 setup for my 2007 Mazda 3 MPS Turbo 3" intake Hpfp 3 bar map sensor 3 port boost controller Cpe tmic Cobb So the situation is I am getting a downpipe custom made to marry up to my custom exhaust. Will the turbo fit onto the stick downpipe ? If so can I fit everything and flash on a base map from justin heath then be able to drive the car to get downpipe fitted? All help appreciated thanks Karl
Post subject: Re: bnr3 setup and help Posted: Wed Mar 09, 2016 4:29 pm |
RM BIK |
Yes, but you'll need yet another base map when the dp goes on.
karl22
Post subject: Re: bnr3 setup and help Posted: Wed Mar 09, 2016 11:47 pm |
Non Member |
How easy is it remove the old turbo and replace it this is just my main concern at the moment
Post subject: Re: bnr3 setup and help Posted: Thu Mar 10, 2016 8:59 am |
RM BIK |
It's pretty straight forward tbh, just take your time. Looking at 3 1/2 hours - 5 if you really take your time
karl22
Post subject: Re: bnr3 setup and help Posted: Thu Mar 10, 2016 2:14 pm |
Non Member |
Ok thanks is it all accessible from the top of the engine
DJJUT
Post subject: Re: bnr3 setup and help Posted: Thu Mar 10, 2016 3:06 pm |
Global Moderator |
Has thanked: 65 times
Been thanked: 137 times
Yes it is..... I find it best to have the front up on axle stands throughout.
karl22
Post subject: Re: bnr3 setup and help Posted: Thu Mar 10, 2016 3:57 pm |
Non Member |
I have a couple of axel stands so I'm good there is that just to get access to the downpipe bolts or just for ease I presume I'll need some wd40 to release some of the bolts haha
DJJUT
Post subject: Re: bnr3 setup and help Posted: Fri Mar 11, 2016 2:32 am |
Global Moderator |
From underneath you can get to the downpipe and turbo oil drain bolts.
