Page 1 of 1 [ 13 posts ]
 Post subject: Hi all :)
 Post Posted: Fri Dec 04, 2015 11:03 am
Hello everyone, my names Ryan and i'll be viewing a mk1 3 MPS next Saturday so thought i'd register with the forum and get to know you all :) i've done a lot of homework so hopefully will spot if its a bad one haha.
I currently own a Toyota Corolla T sport and prior to that my Toyota Celica so will make a change seeing a different emblem on the steering wheel.
I guess my only question is how tuner friendly are these cars? Ive read they can top 300bhp without any major surgery. Does the standard ECU allow for a good tune or is it better to go standalone? The main, and really only, reason for selling my beloved Corolla is that theres litterally no mods you can buy off the shelf, everything has to be custom and ive most definately paid the price in my wallet haha so just want a car that is very tuner friendly and maybe further down the road can buy bolt on parts (oh ive dreamt of just bolting on parts for so long! :D )
Anyway sorry to bore you all, just very excited to start a new project :)
Ryan
 Post subject: Re: Hi all :)
 Post Posted: Fri Dec 04, 2015 12:49 pm
:welcome: to :mpsoc: Ryan
The mps is very tuner friendly, but has to be done in certain steps otherwise it can to lead too serious issues.
The ecu is mapped easily with a cobb access port or versatune. Search them on here and online and you'll get the jist, 99% of us use Justin (DJJUT) on here to mapp us with said items, via email.
 Post Posted: Fri Dec 04, 2015 2:43 pm
:welcome: :mpsoc: Fella Good choice Mk1 :thumbs:
 Post Posted: Fri Dec 04, 2015 4:09 pm
Many thanks for the welcome guys :) great to hear that the stock ecu is fine for tuning, the denso that comes on the Corolla/Celica is factory locked so had to buy an EMS-4.
I know this is probably impossible but other than the obvious visual modifications, how can i tell if a car has been tuned its whole life and then just detuned to stock for resale?
Many thanks and sorry for all the questions
 Post Posted: Wed Dec 09, 2015 12:05 am
Hi Ryan. :welcome: along to :mpsoc:
It can be quite hard to tell. My advice would be to try and find a
clean modded example. They cost very little more than standard cars, plus if you ask on here there is a chance they someone will know the car. They can then tell you if it's a goodun or not.
 Post Posted: Wed Dec 09, 2015 9:19 am
Been thanked: 4 times
Welcome, think I recognise your name from CcUK :D
 Post Posted: Thu Dec 10, 2015 9:13 pm
Bhp: 317
lbf·ft: 326
Welcome to the forum buddy :D
Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
 Post Posted: Thu Dec 10, 2015 11:26 pm
Has thanked: 19 times
Been thanked: 46 times
Welcome to the forum hope you have an easy time finding one
 Post Posted: Fri Dec 11, 2015 1:23 am
Hi and welcome to the forum [WHITE SMILING FACE]
 Post Posted: Sat Dec 12, 2015 2:49 am
Hi LukeSR i didnt know you moved onto an MPS! Glad to know im not the only corolla convert ;) and many thanks again guys for the welcome :)
Well i viewed a car on Tuesday evening and turned out to be a bit ropey. So ive got my eyes on a black one on Autotrader currently going for 6k, seems to tick the boxes for what i want so will organise to make the long trip up to coventry to view it.
 Post Posted: Thu Jan 07, 2016 6:46 pm
 Post Posted: Thu Jan 07, 2016 11:54 pm
Has thanked: 83 times
Hello and welcome :) They seem a good friendly bunch here! :D
 Post Posted: Fri Jan 08, 2016 7:36 am
