Page 1 of 1 [ 10 posts ]
 Post subject: Hello
 Post Posted: Sun May 03, 2015 12:50 pm
Hi everyone,
I've had my 6 for a couple of years and I've been lurking on the site for ages but having finally decided to keep my 6 for the long term I've signed up as a paid memember.
I've had a love/hate relationship with the car but its about time I spend some more money on it!
 Post subject: Re: Hello
 Post Posted: Sun May 03, 2015 2:33 pm
Welcome. What are your loves and hates?
 Post Posted: Sun May 03, 2015 2:41 pm
:welcome: to :mpsoc: ...... :wwp:
Werabouts in Motherwell are u I'm in bellshill not seen a 6 kicking about
 Post Posted: Sun May 03, 2015 4:00 pm
:welcome: along :thumbs:
 Post Posted: Sun May 03, 2015 7:28 pm
I was used to high reving engines so it took me a while to get used to the power delivery of the 6 and I had a few niggly issues such as calipers sticking, leaking power steering pipes and a blown exhaust....but then i take it for a blast and I forgot about all of that!
Gav, I'm living in Carfin now but grew up in Bellshill, where abouts it Bellshill you from?
 Post Posted: Sun May 03, 2015 8:01 pm
Faults are annoying but hopefully you can put those behind you and enjoy the car. A remap extends the rev band but it is still a hard mid range puller. Best come back to the forum on advice about remaps. Loads of knowledge on here.
 Post Posted: Sun May 03, 2015 9:17 pm
I've only been in bellshill for 9 year grew up in uddingston.....im near the orb living now...
You should try getting to one of the meets (last Thursday of the month)
 Post Posted: Sat May 16, 2015 2:12 pm
 Post Posted: Sun May 17, 2015 12:09 pm
:welcome: along to :mpsoc: paid up section.
 Post Posted: Tue Jun 02, 2015 12:10 pm
