Page 1 of 2 [ 18 posts ] Go to page 1, 2  Next
 Post subject: Yooo Hooo
 Post Posted: Sun Apr 26, 2015 9:57 am
Alreet,
I'm new to the forum (using tapatalk for now)
I'm Matt, or "Lippy" to some
I own a 2010 plate Red Mazda 3 MPS MK2. Bought her last year from one of the members on here.
She's a beaut, few niggles here and there but what car doesn't. Gives her character
Will start some basic prodding and modding later on this year so i'll post a bit more often then so just a hello for now !
That's all for now folks
 Post subject: Re: Yooo Hooo
 Post Posted: Sun Apr 26, 2015 11:13 am
 Post Posted: Sun Apr 26, 2015 1:46 pm
Hi and welcome to the family :mpsoc:
 Post Posted: Sun Apr 26, 2015 1:48 pm
Has thanked: 74 times
Welcome to the forum
Nothing!
 Post Posted: Sun Apr 26, 2015 3:48 pm
:welcome: along to :mpsoc:
Nice looking motor. Look forward to reading about your progress.
 Post Posted: Sun Apr 26, 2015 4:21 pm
I'm looking forward to progress too ha ! 'Twill be slow and strung out unfortunately, money's all tied up in my house being rennovated atm.. got to have nice digs so the ball and chain can't complain when Kami gets all the attention [GRINNING FACE WITH SMILING EYES]
 Post Posted: Sun Apr 26, 2015 4:22 pm
Has thanked: 14 times
Been thanked: 18 times
Very shiney :cool:
Tuned with Image
Alcon 6 pot Brake Calipers with 365mm Discs, Cosmis S1 18x9.5 inch alloys and 265/35/18 tyres
Treadstone Front Mount Intercooler Kit. TR1035 core, clamps with piping, and a crash bar!
CorkSport Power Series II SRI, Blitz Bypass Valve
Cobra Single Exit Exhaust and Decat
CorkSport Upper Control Arms adjustability from -0.2 degrees to -2.0 degrees for added and improved control, spherical bearings replace the soft rubber bushings used in OEM and arms for more precise suspension settings
Corksport Rear Camber Arms +/- 5 degrees of camber adjustment
AWR Engine Mount Set
Turbine Tech forward Differential Mount Brace
CPE xFlex™ Rear Differential Mount
Whiteline Upgraded Anti Roll Bar
Bilstein B12 Pro Suspesion Kit
RX8 R3 Recaro's, Retrimmed RX8 R3 Steering wheel in Leather and Alcantara with Red stitching. James Barone Racing - Short Shift Kit and JBR Heavy Gear Knob.
Evo X rear Spoiler LED rear lights
VersaTuner map
 Post Posted: Sun Apr 26, 2015 4:45 pm
:welcome: to :mpsoc:
Best and fastest colour :thumbs:
 Post Posted: Sun Apr 26, 2015 6:51 pm
Has thanked: 16 times
lbf·ft: 340
Welcome, looks mint! ;)
Current Mods :: K&N Typhoon SRI :: Corksport TIP :: Powerflow 2nd Decat :: Forge V1 BPV :: ASI TMIC :: Cobb 3-Port :: VibraTechnics REM :: Koni STR.Ts (Rear) :: Rainsport 3s ::Image (J-Tune In Progress)
Selling up :( ::
 Post Posted: Mon Apr 27, 2015 1:59 am
 Post Posted: Mon Apr 27, 2015 6:10 am
 Post Posted: Mon Apr 27, 2015 11:51 am
Bhp: 294
lbf·ft: 324
true red mk1 3MPS, Hypertech tune, Corksport SRI+TIP, Resonator and 2nd Cat removed, Powerflow custom exhaust, Turbosmart BPV, J-Speed short shift plate, Lowered 40mm H&R springs, Gloss black RX-8 alloys, Mazdaspeed stubby carbon Ariel, XCarlink.
 Post Posted: Mon Apr 27, 2015 12:06 pm
:welcome: :mpsoc: Love the Red :thumbs:
 Post Posted: Mon Apr 27, 2015 5:42 pm
Thanks for the warm welcome
 Post Posted: Mon Apr 27, 2015 7:49 pm
Hello mat looked clean the other day when I seen you
