yetam
Post subject: Hi Posted: Mon Feb 23, 2015 10:59 am |
Hi all it's Ben and recently bought a 3. Im parking on the driveaway but insurance knows in garage. is that something i need to change in the policy? can anyone suggest a good place nearby for bodywork done?
Post subject: Re: Hi Posted: Mon Feb 23, 2015 11:16 am |
 Ben Where are you? Put it in your profile  Yeah you should tell your insurance really
ShaunyG
Post subject: Re: Hi Posted: Mon Feb 23, 2015 11:32 am |
Joined: Mon Jan 02, 2012 5:15 pm Posts: 4205 Location: Sheffield Vehicle: other
Has thanked: 2 times
Been thanked: 13 times
_________________ Mazda 3 MPS Crystal White Pearl Mk2 - Stock
BLUNTY
Post subject: Re: Hi Posted: Mon Feb 23, 2015 12:03 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
Kenny
Post subject: Re: Hi Posted: Mon Feb 23, 2015 12:24 pm |
Been thanked: 11 times
Like sir spamalot says update your profile
EliotG
Post subject: Re: Hi Posted: Mon Feb 23, 2015 12:35 pm |
Joined: Wed May 01, 2013 10:36 am Posts: 566 Vehicle: MPS3 mkI aero
Been thanked: 9 times
Hi Ben, welcome to the forum. Where abouts are you based?
Yes, you need to inform your insurance about where you park you car as it could invalidate your insurance if you don't.
_________________ Mods: JBR SRI/TIP || JBR Shifter Bushings || SF SSP || Custom 2nd Decat + Silencer || Forge v2 BPV || Cobb v2 || J-Tune || Bilstein B8
Beds_MPS
Post subject: Re: Hi Posted: Mon Feb 23, 2015 12:41 pm |
Joined: Sat Jun 30, 2012 9:20 pm Posts: 3039 Location: Beds Vehicle: MPS3 mkI
Has thanked: 25 times
Been thanked: 122 times
Welcome to the forum. I have a choice of driveway or road for parking mine and when I looked into the insurance road was cheaper (I've heard that it's better as car thieves don't know which house to rob for the keys).
_________________ Used to have : 2008 MK1 3MPS Cosmic Blue -  J-Tuned, stainless steel dials, eBay TIP, Sure SSP, Sure Anchors, K&N Replacement, Drilled Airbox, LED side lights, LED interior lights, LED reverse light, MTEC drilled discs, Yellow Stuff pads, NGK LTR7IX-11, EGR block off. Now: 2005 Corolla T-Sport
DrewMPS
Post subject: Re: Hi Posted: Mon Feb 23, 2015 2:43 pm |
Joined: Sat Dec 28, 2013 3:25 pm Posts: 158 Location: Lancashire Vehicle: MPS3 mkI aero
lbf·ft: 322
Welcome to MPSOC.
I would tell your insurers, as if it was stolen it may cause you issues (may not invalidate) as to why it wasn't in the garage.
I think it was Flux wouldn't cover me unless my car was garaged.
Post subject: Re: Hi Posted: Mon Feb 23, 2015 2:49 pm |
 along
Gav1888
Post subject: Re: Hi Posted: Mon Feb 23, 2015 4:17 pm |
Has thanked: 56 times
Been thanked: 28 times
 to  .......insurance usually cheaper if it's parked on street...insurance look at it as if in drive or garage thiefs know wat house to break into for keys...also with keeping it in a garage U. Would be surprised to how many claims go through for roofs collapsing onto car or things being stored above car falling on top.....
yetam
Post subject: Re: Hi Posted: Tue Feb 24, 2015 9:37 am |
Thanks a lot everyone. I'm Ben from Dover. Thought mps are discreet? I shall invite them with my katana should they try to break in house for keys.
Jim
Post subject: Re: Hi Posted: Tue Feb 24, 2015 9:51 am |
| Founder |
Joined: Fri Feb 05, 2010 1:33 pm Posts: 7153 Location: Urmston Vehicle: RX7
Has thanked: 4 times
Been thanked: 55 times
yetam wrote: Thanks a lot everyone. I'm Ben from Dover. Thought mps are discreet? I shall invite them with my katana should they try to break in house for keys. Fuck off. You Dick. Mr T wrote: Try to learn how to be fair, fuck ur warning and ban me like I care. If you didn't care, why do you keep coming back? That question is rhetorical. Just so you are aware, you will now be invoiced for the membership you claimed back via paypal, as you've breached T's and C's
Post subject: Re: Hi Posted: Tue Feb 24, 2015 10:06 am |
Excellent spot Jim.
Piss off Tanim, you're not welcome here
sternritter
Post subject: Re: Hi Posted: Tue Feb 24, 2015 10:30 am |
Joined: Tue Jun 04, 2013 2:17 pm Posts: 4200 Location: Wolverhampton Vehicle: MPS3 mkII
Has thanked: 7 times
Been thanked: 10 times
Jim wrote: yetam wrote: Thanks a lot everyone. I'm Ben from Dover. Thought mps are discreet? I shall invite them with my katana should they try to break in house for keys. Fuck off. You Dick. Mr T wrote: Try to learn how to be fair, fuck ur warning and ban me like I care. If you didn't care, why do you keep coming back? That question is rhetorical. Just so you are aware, you will now be invoiced for the membership you claimed back via paypal, as you've breached T's and C's  love it Jim .
_________________  If you want to play be ready to pay ££ MPS NOW SOLD , COME FORTH THE X-TYPE (RIP) , COME FORTH THE BRAVO DERV
BNRS3 HTP 3" INTAKE AUTOTECH HPFP FORGE INTERCOOLER TOTAL MPS DOWNPIPE KFORD TYRES 3" PIPEWORK & MIJ BACKBOX COBB 3PORT EBS DICE DUST CAPS TB COOLANT DELETE FORGE V2 BPV JBR REM 88a DAGHER TUNED 3Bar Map Sensor
Test Drives Unltd
Post subject: Re: Hi Posted: Thu Feb 26, 2015 1:54 pm |
Joined: Tue Jan 11, 2011 10:48 pm Posts: 1579 Location: West Sussex Vehicle: Toyota
