Page 1 of 1 [ 4 posts ]
 Post subject: Rear Light Cluster
 Post Posted: Wed Aug 27, 2014 12:15 pm
Good Afternoon Everybody
Newbie here , I have a 2012 and previously a 2010 mazda 3 MPS and on both models after about a year the lower edges of the rear light clusters start getting a green / black mould /sludge on the inside edges ! I was just wondering if anyone else has had this and if mazda were aware and would do anything about this issue .
 Post subject: Re: Rear Light Cluster
 Post Posted: Wed Aug 27, 2014 12:26 pm
Been thanked: 19 times
I had this when I bought my 6. Ended up taking the rear lights off and cleaning it out properly. Its pretty easy once you find the bolts behind the boot trim
 Post Posted: Wed Aug 27, 2014 12:42 pm
Has thanked: 23 times
Been thanked: 21 times
There's a spider in one of mine, is it simple enough once they are out? What precautions should you take so they don't mist up?
Stock 6 MPS : because it's fine as it is!
 Post Posted: Wed Aug 27, 2014 12:57 pm
Been thanked: 5 times
2012 still in warranty got to be worth a trip to mazda you never know your luck
Users browsing this forum: No registered users and 25 guests
