BanzaiMike
Post subject: Re: New member Posted: Fri Nov 07, 2014 11:01 am |
Joined: Sun Sep 16, 2012 8:00 pm Posts: 2275 Location: Stockport Vehicle: MPS2
Has thanked: 3 times
Been thanked: 26 times
Hi and welcome to the asylum
_________________ New motor - 2015 Mazda 2 Skyactiv 115 Sport Nav Previous motor - 2010 Mazda 3 MPS running BNR S3 Snail and the usual bolt ons.
ffz
Post subject: Re: New member Posted: Sat Nov 08, 2014 2:21 pm |
Joined: Mon May 27, 2013 7:01 pm Posts: 2940 Location: Doncaster Vehicle: MPS3 mkII
Has thanked: 6 times
Been thanked: 8 times
 to  !! Get a MK2, excellent car! Way better than the ST, VXR, GTI, WRX etc
_________________ I got some mods...
SilverSport
Post subject: Re: New member Posted: Sat Nov 08, 2014 3:22 pm |
Joined: Thu Feb 27, 2014 3:56 pm Posts: 665 Vehicle: other
Been thanked: 15 times
Welcome to the  forum. Another vote here for a Mk2, I'm not biased or anything
Gav1888
Post subject: Re: New member Posted: Sat Nov 08, 2014 3:24 pm |
Has thanked: 56 times
Been thanked: 28 times
Welcome ....I'm not biased either so I would go with mk2 as well
rick6
Post subject: Re: New member Posted: Sat Nov 08, 2014 3:32 pm |
Joined: Mon May 19, 2014 5:14 pm Posts: 217 Location: Andover, Hampshire Vehicle: MPS6
Welcome along. Just take your time and buy a good one. Search on here about issues etc before buying.
BLUNTY
Post subject: Re: New member Posted: Sat Nov 08, 2014 3:55 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
 to the Madhouse  MK1 is faster!
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
ffz
Post subject: Re: New member Posted: Mon Nov 10, 2014 5:18 am |
BLUNTY wrote: :welcome: to the Madhouse  MK1 is faster!  Oh really? The Mk1 feels faster in the way it delivers the delivers the power and the noise it makes. The Mk2 is a little too quiet stock, but a full decat soon sorts that.
Test Drives Unltd
Post subject: Re: New member Posted: Thu Nov 27, 2014 10:56 pm |
Joined: Tue Jan 11, 2011 10:48 pm Posts: 1579 Location: West Sussex Vehicle: Toyota
