Page 1 of 1 [ 3 posts ]
 Post subject: The new guy questions
 Post Posted: Mon Apr 23, 2018 5:03 pm
Trying get to get to grips with new car mk1 mazda 3 07 prev owner has. Upgraded most suspension parts and few other bits. I've just done a oil change and now need to look at service parts. Where are the spark plugs and how to access them.
And I saw a video on how to change cabin air filter seems alot of effort for this is there an easier way?
 Post subject: Re: The new guy questions
 Post Posted: Tue Apr 24, 2018 9:28 am
Found most things now
 Post Posted: Tue Apr 24, 2018 1:24 pm
Install time:10-20min
Tools needed:
Ratchet set
4 new spark plugs (a good choice for standard engine would be NGK ILTR6A-8G 3787)
For those who have not upgraded to a FMIC you will have to remove your TMIC. You will need:
2x 10mm for cover
3x 12mm for TMIC
Loosen up the hose clamps for the boost tubes.
Pull up, shake as needed and take the TMIC Off.
First you need to locate where your plugs are. They are under these 4 black caps (which are the ignition coils) w/ grey connectors at the end of them.
Next you will need to disconnect the grey connectors and unscrew the screws on top of the ignition coils 8mm
Next pull the ignition coils out, the spark plugs are underneath
Next use your ratchet to get the old plugs out and put them in the trash. Before putting your new plugs in use a spark plug gap gauge to check and fix the gap on your plugs. The correct gap is 0.8mm, they should come pre-gapped anyway.
Fit new plugs, carefully, without cross threading them.
Put the rest back together.
Simples.
2007 MPS3 - K&N Typhoon, HKS SSQV BOV, Autotech Internals, Banjo Bolt, TotalMPS TMIC, VersaTuner, EGR Delete, Vibra Technics REM, 2nd Decat, Small Resonater Delete, Tints, Smoked Side Indicators, Painted Callipers, Aeroforce Interceptor, JBR Weighted Shifter, Aero Spoiler, Re-Amemiya Rear Wing Lip, Eibach Spacers, Stoptech Cross Drilled Discs and Pads all round, Custom Flat Bottom/Retrimmed Steering Wheel, Bola B1's 18x8.5 Alloys, Eonon GA7151 Stereo, Rally Flaps, Rear Diffuser, Full Set of Uniroyal Rainsports, J-Tuned!
- Purchased 01/03/2016
- Interim Filters/Oil Service/Plugs 27/03/2016
- Major Service (VVT, Chain, Belt, Tensioner, Idler Pulley) 30/08/2016 by Crayford Mazda (Wayne Miller)
- Interim Filters/Oil Service 01/09/2017
Users browsing this forum: Google [Bot] and 1 guest
