Page 1 of 1 [ 6 posts ]
 Post subject: New member in surrey
 Post Posted: Fri Apr 15, 2016 6:21 pm
Hi all new Surrey member here . Got my black mps6 in January and love it.i thought I best introduce myself before I start asking for advice on a few things.
 Post subject: Re: New member in surrey
 Post Posted: Fri Apr 15, 2016 6:52 pm
Welcome along. Well worth joining up to get full advantage of membership.
 Post Posted: Sat Apr 16, 2016 12:26 am
:welcome: :mpsoc: :wwp:
 Post Posted: Sun Apr 17, 2016 10:10 am
Has thanked: 61 times
Been thanked: 17 times
Welcome. Which part of Surrey are you from?
Sent from my Vodafone Smart ultra 6 using Tapatalk
2007 6MPS
  • Power: Autotech HPFP, COBB AP V3, CS 2.5" Intake + TIP, CS BPV, CS TBE, EGR Blockoff
  • Handling: JBR 80A Triology Mounts, Stoptech Slotted Discs
  • Other: Sure SSP, Sure Anchors, LED Interior/Number Plate/Side lights, Dave Plank Dials, Royal Steering Wheel Retrim
  • To be fitted: Mishimoto OCC, FMIC, Blistein B8s, Eibach Springs, Whiteline RARB, CPE & Sure Diff Mounts
 Post Posted: Wed May 11, 2016 9:04 pm
I'm in guildford surrey black 06 MPS
 Post Posted: Sat May 14, 2016 9:20 am
You'd be the one I saw in Guildford this week I assume then!
Sure Full3 Aeros | Forge Recirc | Cobb Accessport v3 | Drilled & Grooved Discs | Redstuff Pads | Autotech HPFP | Jetex Cat-Back | Total TMIC | Lowered 35mm | Sure Short Cut Kit | Bola B1 18" Gunmetal Alloys | AET Hybrid Turbo | XS-Sport Exhaust Manifold | 1st & 2nd Decat
Users browsing this forum: Google [Bot] and 5 guests
