voo2doo
Post subject: And another Posted: Fri Feb 17, 2012 11:19 pm |
Hello people. I am looking at a 6 MPS tomorrow and just thought I'd do a bit of homework before I commit to buy. Is there anything particular I should look out for? Its a 56 plate 74000 its had,quote....TIMING CHAIN, NEW CHAIN ADJUSTERS, NEW TENSIONERS, NEW VARIABLE VALVE TIMING PULLEY. Thanks and I hope to learn alot from you fellas. Oh,i drive at the moment an 04 ST170 with a map. J
sdg_3mps
Post subject: Re: And another Posted: Fri Feb 17, 2012 11:30 pm |
Founder |
Hello &  .
Phil MC
Post subject: Re: And another Posted: Fri Feb 17, 2012 11:54 pm |
MPSOC Member |
Joined: Thu Feb 02, 2012 3:22 am Posts: 248 Location: Glasgow Vehicle: MPS6
Hi and welcome. I too have just bought a 56 reg 6MPS, and I'd say they're reasonably bullet-proof tbh. Just look out for the usual things, smoking turbo, big end knock, clutch slip etc. I'm sure someone else will be along soon to point you in the right direction for other things to look out for.
rusty2503
Post subject: Re: And another Posted: Sat Feb 18, 2012 5:29 am |
MPSOC Member |
Hello and welcome,as above,plus give the brakes discs a good check for ware etc,a lot of guys on here upgrade the brakes so make sure you are going to get a few miles out of them first..
Post subject: Re: And another Posted: Sat Feb 18, 2012 10:13 am |
Global Moderator |
Hi and  to the club mate
Azzaboy
Post subject: Re: And another Posted: Sat Feb 18, 2012 10:15 am |
Joined: Sat Feb 06, 2010 11:42 am Posts: 2087 Location: Dunfermline - Y'Kin! Vehicle: MPS6
Hello and  - check the aircon.
foxy
Post subject: Re: And another Posted: Sat Feb 18, 2012 10:27 am |
MPSOC Member |
Been thanked: 60 times
Is that the condensor pipe rot?
Azzaboy
Post subject: Re: And another Posted: Sat Feb 18, 2012 10:30 am |
daviemps
Post subject: Re: And another Posted: Sun Feb 19, 2012 12:36 am |
Hello and
martin_46
Post subject: Re: And another Posted: Mon Feb 20, 2012 11:17 am |
Senior |
Joined: Mon Jul 26, 2010 7:52 pm Posts: 3761 Location: Aberdeenshire Vehicle: MPS3 mkII
Hello & Best to do all the usual checks, and have a search around the forum for usual stuff, but not many problems at all
_________________ Trying to resist modifying my new Mazda 3 mk2 MPS! viewtopic.php?f=86&t=13680
voo2doo
Post subject: Re: And another Posted: Sun Feb 26, 2012 8:07 pm |
Phil MC wrote: Hi and welcome. I too have just bought a 56 reg 6MPS, and I'd say they're reasonably bullet-proof tbh. Just look out for the usual things, smoking turbo, big end knock, clutch slip etc. I'm sure someone else will be along soon to point you in the right direction for other things to look out for. Thanks,got the MPS on Saturday and when I was at a cafe with the engine ticking over I did notice smoke coming from the exhaust.Will this be the turbo? it's only got three months warranty on it so i need to get the jobs sorted now before it runs out. Thanks in advance. J
ross27
Post subject: Re: And another Posted: Sun Feb 26, 2012 8:15 pm |
Senior |
Joined: Mon Apr 11, 2011 7:52 pm Posts: 5484 Location: Glasgow Vehicle: Nissan
voo2doo wrote: Phil MC wrote: Hi and welcome. I too have just bought a 56 reg 6MPS, and I'd say they're reasonably bullet-proof tbh. Just look out for the usual things, smoking turbo, big end knock, clutch slip etc. I'm sure someone else will be along soon to point you in the right direction for other things to look out for. Thanks,got the MPS on Saturday and when I was at a cafe with the engine ticking over I did notice smoke coming from the exhaust.Will this be the turbo? it's only got three months warranty on it so i need to get the jobs sorted now before it runs out. Thanks in advance. J Ive got this issue just now, see here: viewtopic.php?f=21&t=7340
