Has thanked:3 times
Hi looking for a remap.can people suggest a good company.looked at bbr can stage 1 to 290hp.but are they good.suggesting please.just looking for stage 1 about 300hp.
Joined: Mon Jan 04, 2016 10:00 pm Posts: 307 Vehicle: MPS3 mkII
Has thanked:4 times
Been thanked:23 times
lbf·ft: 350
Hello.
Don't use BBR or any other remapping centers
They simply won't be able to do a good enough job.
Everyone here will suggest you look into buying either a Cobb accessport or Versatuner.
Once you have those you can ask Justin Heath to map your car.
Basically, you take some data logs, send them to Justin, he then sends you a map to upload to the car. You repeat this multiple times until your happy and so is Justin. This is how you should map a car, and is only bettered by a proper live mapping on a rolling road. Something which would cost you £600+
Don't be duped by the companies that have a Dyno and will give you a before and after print out, they don't do live mapping specifically for your car, they will use an off the shelf map which could cause damage.
Also before you start, you MUST have upgraded your fuel pump internals. The MK2 simply won't be able to provide enough fuel pressure to handle any more power It's around £320 and is the first mod you do
_________________ Mazda 3 MK2 Mods: CorkSport TMIC Cobra exhaust CorkSport TIP Bilstein B8 Dampeners with MK1 aero springs In the process of tuning with Justin
Has thanked:12 times
Been thanked:251 times
