 Post subject: Morning all
 Post Posted: Mon Apr 25, 2016 8:48 am
Hi all
New to Mazda, MPS, and your site. Am collecting an 06 6MPS this week and after having been a very active member of other marque sites over the years. I am very aware of the advantage and abundant useful info available I found this site. So a big hello.
Neil sat in Cardiff
 Post subject: Re: Morning all
 Post Posted: Mon Apr 25, 2016 10:39 am
Has thanked: 19 times
Been thanked: 46 times
Hi neil.
Not far from me bud im in bridgend.
 Post Posted: Mon Apr 25, 2016 11:05 am
Also is the 6 you buying a local car or forum members?
 Post Posted: Mon Apr 25, 2016 12:15 pm
:welcome: to a fellow welshman :thumbs:
 Post Posted: Tue Apr 26, 2016 10:18 pm
Bhp: 148
lbf·ft: 138
Hi there Neil Welcome to the Forum.
 Post Posted: Wed Apr 27, 2016 7:11 am
Hi all
Thanks for the replies. Don't think a forum car as I'm aware. Local though to South Wales. Just a few things to sort. Rear left brakes are binding and scraping and I've just searched the driver window controls as it only controls the driver door even when lock is off. Thanks all
 Post Posted: Wed Apr 27, 2016 7:43 am
In regards to windows. Go to each individual window do it down then back up hold up for a couple of seconds you will here a click. This will then work off you drivers control.
Rear brakes sounds like they are on metal. If your not far from bridgend and have no mechanical knowledge pop over i will take a look and change for you if needs be :)
 Post Posted: Wed Apr 27, 2016 10:27 am
This could be the one that's stupidly rusty underneath. Get it on a ramp before you part cash
 Post Posted: Wed Apr 27, 2016 3:30 pm
MPS numbers are starting to increase in South Wales now
Mk2 3 MPS Crystal White Pearl
JBR Stage 2 Power Path Intake. Autotech HPFP, 2nd Cat and resonator delete, Turbosmart BOV, JBR 88a REM, Corksport TMIC, Cobb v3 and Jtune v3
Rear lights tinted red, brake calipers painted
Next to do - Custom exhaust and turbo time
 Post Posted: Wed Apr 27, 2016 9:21 pm
Tell me about it. I bought one as i thought it be rare. Fml
 Post Posted: Thu Apr 28, 2016 4:39 pm
Bhp: 317
lbf·ft: 326
Welcome :D :D :D
Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
 Post Posted: Fri Apr 29, 2016 9:34 am
Hopefully not but if it is having owned an alfa gtv for 12 years I know a man who can. Had to have half of the floor and 5 of the 6 sills replaced yes 6 layers of sill on my alfa.
Done the Windows however near side rear has no power do going to check the connection.
Car has been standing for a while so going yo get a service and the rear brakes done then a full look over this week.
Thanks for the offer of help too!!
Ta
Neil
 Post Posted: Fri Apr 29, 2016 7:47 pm
No probs when its running dont be shy to pop to bridgend got a couple of nice mps around here.
 Post Posted: Mon May 02, 2016 7:11 pm
Has thanked: 21 times
Been thanked: 12 times
Welcome to the forum bud
Autotech internals // HTP 3" Full Intake // CP-E Top Mount // Stoptech Rotors/Pads // HEL braided lines // Corksport Hood Scoop // Cobb AP v3 // GFB Respons // Bilstein B12 Pro Kit // Whiteline Rarb and links // 4" Custom Tips // CFM 9 Peg Army // VVT done at Young Motors // J-Tuned
 Post Posted: Tue May 03, 2016 1:11 am
Has thanked: 168 times
Been thanked: 113 times
Hi and :welcome: along to :mpsoc:
With regard to rear window, have you tried the switch on that door? Reason I ask is that, if the battery is disconnected, you lose the ability to open the windows from the drivers switch. You then have to do the holding the switch thing Darren suggested, but from each individual door.
I have also owned an alfa. (156 2.4 JTD 20v) My favourite car to date. Wanted a 156 GTV instead of my mps, butwas concerned it would end up costing me more to run. :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Most importantly, J Tune!!!!!
