Page 1 of 2 [ 16 posts ] Go to page 1, 2  Next
 Post subject: Velocity mps6
 Post Posted: Thu Apr 16, 2015 10:09 pm
Hi all new member from Southampton.
Loving the 6, having come from a Leon cupra r I love how it can be a very sedate car on the commute.
But when you out your foot down it flys! Taking a while to get used to the semi awd after coming from a fwd hot hatch!
 Post subject: Re: Velocity mps6
 Post Posted: Fri Apr 17, 2015 1:32 am
Has thanked: 168 times
Been thanked: 113 times
:welcome: along to :mpsoc:
Good choice of car and colour.
I'm a fellow southerner! Theirs not enough of us!
Most importantly, J Tune!!!!!
 Post Posted: Fri Apr 17, 2015 5:02 am
:welcome: to :mpsoc:
 Post Posted: Fri Apr 17, 2015 5:37 am
:welcome: to :mpsoc: good choice and nice colour :thumbs:
 Post Posted: Fri Apr 17, 2015 6:10 am
 Post Posted: Fri Apr 17, 2015 11:39 am
Been thanked: 5 times
Welcome mate. You got the best colour.
Nothing!!! Very Sad ZZBOOOOOM!!!!! time for a Derv..........
 Post Posted: Fri Apr 17, 2015 1:04 pm
Welcome along. The 6 is more accurately a front wheel drive that has the ability to transfer up to 50% of its power to the rear wheels in a split second. Cruising along it is fwd, more or less. The 6 should be described as variable wheel drive, VWD, not AWD. Different to a 4WD which drives all 4 wheels permanently.
The 6 is amazing in adverse weather. Superb traction where it works out where to apply the power.
 Post Posted: Fri Apr 17, 2015 6:13 pm
Uhh right didn't know it was fwd while cruising, would this be why I get the feeling of understeer momentarily when I throw it into a corner?
 Post Posted: Sat Apr 18, 2015 11:15 pm
 Post Posted: Sun Apr 19, 2015 7:29 am
 Post Posted: Sun Apr 19, 2015 7:32 am
No, under steer is a trait of AWD cars. Till you br al past that point, then its tail happy but in a controllable way, awesome fun when you get it right
 Post Posted: Mon Apr 20, 2015 8:34 am
welcome to the forum mate :)
Velocity red really is the best colour :D
 Post Posted: Mon Apr 20, 2015 12:45 pm
Hi and :welcome: to the club :thumbs:
 Post Posted: Mon Apr 20, 2015 1:31 pm
Hi and welcome :mpsoc:
 Post Posted: Thu Apr 23, 2015 8:54 pm
Has thanked: 74 times
welcome to the forum :D
Nothing!
Users browsing this forum: Google [Bot] and 1 guest
