Page 2 of 2 [ 22 posts ] Go to page Previous  1, 2
 Post subject: Re: Hi
 Post Posted: Wed Feb 18, 2015 2:19 pm
:welcome: to you sir :mpsoc:
 Post Posted: Wed Feb 18, 2015 2:27 pm
:welcome: to :mpsoc: .....happy modding :thumbs:
 Post Posted: Wed Feb 18, 2015 2:31 pm
Welcome to the nuthouse, prepare to have your money removed for many many modz and powerz :mpsoc:
 Post Posted: Thu Feb 19, 2015 6:57 pm
Nice low miles :thumbs: my 08 is only on 24k :mosh: :D
 Post Posted: Thu Feb 19, 2015 8:32 pm
And in under 2 weeks ownership someone has smashed into the front drivers side of it when it was parked up :( Pissed off is an understatement. Hope it doesn't get written off..
 Post Posted: Thu Feb 19, 2015 8:50 pm
Ouch unlucky mate sorry to hear that......hope everything goes ok with insurance...
 Post Posted: Fri Feb 20, 2015 6:32 pm
You do not have the required permissions to view the files attached to this post.
