sternritter
Post subject: Re: Out with the old, in with the new.... Posted: Mon Nov 25, 2013 10:25 pm |
Has thanked: 7 times
Been thanked: 10 times
Titan wrote: sternritter wrote: If you want full noise , you need to go catless all the way from the turbo and probably 3" and a tiny backbox. So you will need a fuel pump and map. Wouldn't catless cause problems come mot emissions testing time? I bought a catless cobra for my vxr but then had to have a sports cat fitted to pass my mot Find a friendlier MOT guy
ffz
Post subject: Re: Out with the old, in with the new.... Posted: Mon Nov 25, 2013 10:26 pm |
Joined: Mon May 27, 2013 7:01 pm Posts: 2940 Location: Doncaster Vehicle: MPS3 mkII
Has thanked: 6 times
Been thanked: 8 times
no, just give the MOT tester a reacharound. and  to the  !!
_________________ I got some mods...
Titan
Post subject: Re: Out with the old, in with the new.... Posted: Mon Nov 25, 2013 10:56 pm |
Joined: Mon Nov 11, 2013 9:40 pm Posts: 69 Location: Thatcham, Berks Vehicle: MPS3 mkII
I'd rather my setup be all above board and MOT acceptable so catless isn't an option for me
sternritter
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 7:31 am |
Titan wrote: I'd rather my setup be all above board and MOT acceptable so catless isn't an option for me Ahhhh ,well get someone to well a 200 cell cat into the downpipe .job jobbed
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 12:02 pm |
Titan wrote: I'd rather my setup be all above board and MOT acceptable so catless isn't an option for me In that case you can't even remove the second cat then
Titan
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 12:31 pm |
SpamFace wrote: Titan wrote: I'd rather my setup be all above board and MOT acceptable so catless isn't an option for me In that case you can't even remove the second cat then Im assuming then that my only option is just a Cat Back system Would i get away without doing any other mods, or would i still require tuning etc?
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 12:35 pm |
The stock exhaust is good for upto about 400bhp so you'd only change it for audio (but to get to anywhere near that figure the DP has to be changed) What you can get away without a map and stock exhaust is HPFP internals Sri & tip Tmic If you do want a deeper sounding exhaust the a cat back is for you But to get te best out of them will require a map.
sternritter
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 12:36 pm |
Titan wrote: SpamFace wrote: Titan wrote: I'd rather my setup be all above board and MOT acceptable so catless isn't an option for me In that case you can't even remove the second cat then Im assuming then that my only option is just a Cat Back system Would i get away without doing any other mods, or would i still require tuning etc? No i took mine from the 2nd cat all the way back. I will tell you know if you just go for a catback alone you will be dissapointed sound wise.IMO its a waste of cash ,if you get underneath the car you can see the stock system is very good. The backbox is massive but even mine since ive changed it isnt what you expect even on a cold start.
Titan
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 12:58 pm |
sternritter wrote: No i took mine from the 2nd cat all the way back.
The backbox is massive but even mine since ive changed it isnt what you expect even on a cold start. Hmm yeh i can see where you're coming from, best quote i had for a cat back system was £499 including VAT so like you say it's a lot of money for just noise.
readie1983
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 1:01 pm |
Joined: Tue Nov 01, 2011 2:49 pm Posts: 1726 Location: hull Vehicle: MPS3 mkI aero
Just do a second decat and 1st resonator removal. That gives a nice burble
Titan
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 1:19 pm |
readie1983 wrote: Just do a second decat and 1st resonator removal. That gives a nice burble Does that setup still pass the emissions test for MOT then?
sternritter
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 1:37 pm |
Titan wrote: readie1983 wrote: Just do a second decat and 1st resonator removal. That gives a nice burble Does that setup still pass the emissions test for MOT then? Probably pass the emissions ,but won't pass the mot as you need 2 cats in place
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 2:19 pm |
sternritter wrote: Titan wrote: readie1983 wrote: Just do a second decat and 1st resonator removal. That gives a nice burble Does that setup still pass the emissions test for MOT then? Probably pass the emissions ,but won't pass the mot as you need 2 cats in place Thats if they notice you should have 2 cats, many on here have past mot's without any issues with the 2nd cat removed
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 3:21 pm |
richie3mps wrote: sternritter wrote: Titan wrote: readie1983 wrote: Just do a second decat and 1st resonator removal. That gives a nice burble Does that setup still pass the emissions test for MOT then? Probably pass the emissions ,but won't pass the mot as you need 2 cats in place Thats if they notice you should have 2 cats, many on here have past mot's without any problems with the 2nd cat removed  This is true. But on new mot's now, the computer system at the garage is now linked to VOSA/DVLA or whoever it may be and it then states, 1 cat, 2 cats etc
Post subject: Re: Out with the old, in with the new.... Posted: Tue Nov 26, 2013 4:58 pm |
Reacharound it is then The second cat is easy enough to swop in and out come mot time anyways, go for it..you know you want to
