Page 1 of 1 [ 3 posts ]
 Post subject: MySQL Error on UCP
 Post Posted: Tue Jun 12, 2012 9:57 am
Bhp: 330
lbf·ft: 345
FYI... When you select looking to buy MPS as your vehicle on the UCP profile section the forum throws a MySQL error.
Code:
General Error
SQL ERROR [ mysql4 ]
Data too long for column 'user_icq' at row 1 [1406]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Also sorry if this is in the wrong place.
-AeroX
J-Tuned 6MPS
BBR: Hybrid Turbo CS: Short DP|Resonated Decat|Tow Plate JBR: BSD|EGR|REM|Oil Baffle|Shift Weight SU: TMIC|Shift Bushings
3 BAR MAP / AutoTec HPFP / Banjo Bolt / Bilstein B12 / COBB EBCS / HTP 3" Intake / Jetex CBE / NGK LTR71X / OCC / Diff Bushes / TB Coolant Bypass / TurboSmart BPV / Whiteline RARB / EBC YellowStuff / MTEC Dimple&Groove / SPC Ball Joints / SURE ShortCut / AuxMod / BlendMount ScanGauge2 / Block8head & RPM Store Vent Pods / Prosport Gauges
Tuned with :VersaTune: by DJJUT
 Post subject: Re: MySQL Error on UCP
 Post Posted: Tue Jun 12, 2012 10:28 am
Code:
General Error
No worries :welcome: thank you for letting us know
 Post Posted: Tue Jun 12, 2012 2:52 pm
Vehicle: Bishi
Has thanked: 8 times
Been thanked: 44 times
Bhp: 176
should be ok now
