Page 1 of 1 [ 12 posts ]
 Post subject: lowering springs for mk1 3 mps without dampers????
 Post Posted: Mon Apr 09, 2012 10:57 am
Bhp: 347
lbf·ft: 378
hi there can anyone advice me i have a mk1 3 mps on a 06 plate its not a aero. i am looking at getting some lowering spring for it. what i would like to know is would it be ok to just install the springs without changing the dampers or would this not be a good idea.
the car has done 33000 miles. i know they say you should change both but i just wondered would it be possiable..
thanks for any replies....
 Post subject: Re: lowering springs for mk1 3 mps without dampers????
 Post Posted: Mon Apr 09, 2012 11:02 am
You could change to the same as the Aero model, but depending on price I would personally be pretty tempted to look into the Bilstein ones with spring and damper...have a look around on the forum for more info on them :thumbs:
 Post Posted: Mon Apr 09, 2012 11:08 am
Bhp: 320
Yer i agree, the 3 and the 3 aero have the same dampers, meaning the aero is underdamped with the eibach springs.
I believe bilstein b12s are the eibach springs with bistein b6 dampers, probably the best option. i am looking at getting some b6s for mine.
 Post Posted: Mon Apr 09, 2012 11:10 am
Bhp: 347
lbf·ft: 378
on the aero model wasnt it the dampers and springs they changed from stock. it wasnt just the springs they changed was it????
 Post Posted: Mon Apr 09, 2012 11:14 am
Bhp: 347
lbf·ft: 378
the Bilstein and eibach pro kit lowers it i think about 25mm front 15mm rear and they come in at about just under 600.00 does that sound a fair price or should i be looking somewhere else????
 Post Posted: Mon Apr 09, 2012 11:24 am
dont know about the dampers but i kniw the springs are differant and havnt caused any problems. coil oves are an option if you can budget for it. putting the aero springs on is the cheeper option i have read people getting mazda to do it and the only charge about £300 fitted but can be done for alot less if you get an idependant gagage to fit them.
 Post Posted: Mon Apr 09, 2012 11:28 am
i think xopower can supply the aero springs
 Post Posted: Mon Apr 09, 2012 2:51 pm
Bhp: 347
lbf·ft: 378
my mazda dealer told me the springs cost 160.00 plus vat. (blue ones) the ones i was looking at where the eibach pro spring that lower 25mm front and 15mm back. the aero spring were 10mm drop all round wernt they.....
 Post Posted: Mon Apr 09, 2012 3:01 pm
You'll be fine fitting eibach springs to your aero and shop about for fitting as it shouldn't cost too much at all.where are you based?
 Post Posted: Mon Apr 09, 2012 3:14 pm
Try online you should manage to get them £100-£120 I think :thumbs:
 Post Posted: Mon Apr 09, 2012 4:28 pm
i think the aero is 25mm lower
 Post Posted: Mon Apr 09, 2012 6:29 pm
Guest
We have eibachs in stock for all Mps models
