Page 1 of 1 [ 9 posts ]
 Post subject: Hello....need some advise !
 Post Posted: Sun Sep 25, 2011 4:39 pm
Hi all...
I have a bit of an issue with my 2006 Mazda 6 MPS....and wonder if the problem has an easy/obvious solution
It had a service last week and from running very well with no problems whatsoever it now seems to judder quite badly under acceleration above 4,000rpm. Under normal driving, cruising speeds and gentle acceleration all is fine...in fact I drove 180 miles back from Wales today and with cruise-control on at 75-80 mph all was ok. However, any kind of fun results in an apparent loss of power and quite heavy juddering.
The garage who did the service is not a Mazda specialist and has changed the spark plugs already but to me it seems more like a fuel/air mix issue or turbo problem....again I need to stress that the car ran perfectly well before the service.
I haven't checked with a franchised dealer yet because of serious problems I encountered with the Mazda dealer I bought the car from.
Any suggestions greatfully appreciated
Regards
Chris
 Post subject: Re: Hello....need some advise !
 Post Posted: Sun Sep 25, 2011 4:44 pm
Sounds exactly like what I had a week or so ago. Turned out to be plugs.
The fact that a non-Mazda specialist has done your plugs (same as me again - will do them myself from now on!) leads me to conclude that you've got incorrectly gapped plugs in. What plugs did you put in? :)
Read =THIS= thread if you can be arsed. Better still, just go outsid and put your old plugs back in and be amazed that your car works again :D
 Post Posted: Sun Sep 25, 2011 4:46 pm
I'd say incorrect spark plugs fitted... Lots of similar issues lately and spark plugs have been the problem.
Find out what ones they fitted and get a new set of standard ones fitted :thumbs:
 Post Posted: Sun Sep 25, 2011 5:26 pm
cheers guys....many thanks....
I will take it back tomorrow and insist on another set. Can't check old ones as they have been thrown out.
Fingers crossed !!!
 Post Posted: Sun Sep 25, 2011 5:29 pm
Get them to double check there numbers and be sure it's for the MPS :thumbs:
 Post Posted: Sun Sep 25, 2011 6:09 pm
And make sure they're gapped correctly! There've been a tonne of incorrectly gapped plugs reccently and they should be 0.8mm :)
 Post Posted: Sun Sep 25, 2011 6:30 pm
Bhp: 280
agree with the plugs suggestion, either badly gapped or the wrong type.
Sure Aeros SRI Sure Sidewinder TIP and Sure Return. Goodyear Eagle F1 Asymmetric 2's. NGK ILTR6A-8G Spark Plugs.
 Post Posted: Sun Sep 25, 2011 6:35 pm
Just found this on StreetUnit. The first review post raises issues about the coil packs and springs, which I don't understand, but it makes an important point about hesitation etc.
http://www.streetunit.com/DENSO_IRIDIUM ... /itv22.htm
 Post Posted: Fri Sep 30, 2011 12:16 pm
NGK ILTR6A-8G plugs fitted and all is well !!!
Thanks for the feedback
;o)
