Author |
Carbo33
Post subject: Hi All Posted: Sat Feb 22, 2020 10:01 pm |
Non Member |
Joined: Sat Feb 22, 2020 9:45 pm Posts: 5 Location: Manchester Vehicle: MPS3 mkII
Hi everyone, I'm new to the forum but have had several mazda 3 from the 1.6 TS to the Sport and now the owner of a 63 plate MPS   Planning on taking it to BBR for a stage two upgrade but still doing my research and mulling it over. Looking forward to getting to know you all and hopefully coming on a few meets.    Sent from my SM-N960F using Tapatalk
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 2:27 am |
RM BIK |
Hello and welcome. Don't take it anywhere regards the tuning. Get parts yourself and fit them if you're ok with some spanners or get a garage to do them, then get a map using either cobb access port or versatune and get a tuner to e tune you. I hugely recommend freektune. https://www.freektune.com/
Carbo33
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 9:22 am |
Non Member |
Spam man wrote: Hello and welcome. Don't take it anywhere regards the tuning. Get parts yourself and fit them if you're ok with some spanners or get a garage to do them, then get a map using either cobb access port or versatune and get a tuner to e tune you. I hugely recommend freektune. https://www.freektune.com/Hi, thanks for the advice mate. I had contemplated doing my own mods and getting the access port but I've read so many good things about the BRR stage 2 and 3. The downpipe from the turbo is also supposed to be a nightmare to get to isn't it? Any suggestions on mods to take it up to around 320 - 350? I know the fuel pump will need upgrading. Sent from my SM-N960F using Tapatalk
Ilikesleepers
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 10:39 am |
Joined: Sat Sep 01, 2018 10:00 am Posts: 124 Location: West Wales, sometimes south Wales! Vehicle: MPS3 mkI
Has thanked: 6 times
Bhp: 290
Carbo33 wrote: Hi everyone, I'm new to the forum but have had several mazda 3 from the 1.6 TS to the Sport and now the owner of a 63 plate MPS   Planning on taking it to BBS for a stage two upgrade but still doing my research and mulling it over. Looking forward to getting to know you all and hopefully coming on a few meets.    Sent from my SM-N960F using Tapatalk Hi mate, welcome to the forum. Do you mean Bbr GTI?
Carbo33
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 12:50 pm |
Non Member |
Ilikesleepers wrote: Carbo33 wrote: Hi everyone, I'm new to the forum but have had several mazda 3 from the 1.6 TS to the Sport and now the owner of a 63 plate MPS   Planning on taking it to BBS for a stage two upgrade but still doing my research and mulling it over. Looking forward to getting to know you all and hopefully coming on a few meets.    Sent from my SM-N960F using Tapatalk Hi mate, welcome to the forum. Do you mean Bbr GTI? Thanks pal, yeah haha bloody auto corrected because I'd been taking about BBS alloys. Was thinking of going straight for the phase 2 "320" Sent from my SM-N960F using Tapatalk
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 2:41 pm |
RM BIK |
Carbo33 wrote: Spam man wrote: Hello and welcome. Don't take it anywhere regards the tuning. Get parts yourself and fit them if you're ok with some spanners or get a garage to do them, then get a map using either cobb access port or versatune and get a tuner to e tune you. I hugely recommend freektune. https://www.freektune.com/Hi, thanks for the advice mate. I had contemplated doing my own mods and getting the access port but I've read so many good things about the BRR stage 2 and 3. The downpipe from the turbo is also supposed to be a nightmare to get to isn't it? Any suggestions on mods to take it up to around 320 - 350? I know the fuel pump will need upgrading. Sent from my SM-N960F using Tapatalk You won't hear good things about BBR on here. With the MPS, they are shocking. Lots of horror stories, tonnes of regrets on the facebook group too. Honestly, go the etune route. The dp can be a bit of a pita but it's nothing too extreme, just swearing at seized bolts ha. For 350, you'll need a bigger turbo.
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 2:46 pm |
RM BIK |
BBR use generic downloaded maps for the mps, that's not a good thing. Also, people have gone there for parts fitted, paid, then later down the line found out the parts were never fitted, Jonny Gwango paid thousands and thousands to them, including for forging his engine, didn't use his parts etc. Be wary.
Ilikesleepers
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 4:45 pm |
Bhp: 290
I've got the BBR 290 phase 1 running on my car that was put on by the previous owner, I've not had any problems so far, it's been on the car for about 4 years and 18000 miles. The software they use is ecutek I believe.
Something to be aware of is that BBR lock your ecu after the remap so if you then wanted to go down the etune route you'd have to go back to BBR to unlock the ecu which is something I'm considering doing.
I've heard only good things about freektune...
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 5:18 pm |
RM BIK |
Ilikesleepers wrote: I've got the BBR 290 phase 1 running on my car that was put on by the previous owner, I've not had any problems so far, it's been on the car for about 4 years and 18000 miles. The software they use is ecutek I believe.
I've heard only good things about freektune... They charge you £75-125 to unlock it too. I've unlocked other BBR cars for people for free, as have other ecutek garages.
Ilikesleepers
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 5:57 pm |
Bhp: 290
Spam man wrote: Ilikesleepers wrote: I've got the BBR 290 phase 1 running on my car that was put on by the previous owner, I've not had any problems so far, it's been on the car for about 4 years and 18000 miles. The software they use is ecutek I believe.
I've heard only good things about freektune... They charge you £75-125 to unlock it too. I've unlocked other BBR cars for people for free, as have other ecutek garages. I asked a local to me ecutek garage recently if they could unlock my ecu and they told me I'd have to go back to BBR. How is it done?
Carbo33
Post subject: Re: Hi All Posted: Sun Feb 23, 2020 10:30 pm |
Non Member |
Spam man wrote: Carbo33 wrote: Spam man wrote: Hello and welcome. Don't take it anywhere regards the tuning. Get parts yourself and fit them if you're ok with some spanners or get a garage to do them, then get a map using either cobb access port or versatune and get a tuner to e tune you. I hugely recommend freektune. https://www.freektune.com/Hi, thanks for the advice mate. I had contemplated doing my own mods and getting the access port but I've read so many good things about the BRR stage 2 and 3. The downpipe from the turbo is also supposed to be a nightmare to get to isn't it? Any suggestions on mods to take it up to around 320 - 350? I know the fuel pump will need upgrading. Sent from my SM-N960F using Tapatalk You won't hear good things about BBR on here. With the MPS, they are shocking. Lots of horror stories, tonnes of regrets on the facebook group too. Honestly, go the etune route. The dp can be a bit of a pita but it's nothing too extreme, just swearing at seized bolts ha. For 350, you'll need a bigger turbo. Looks like I'll be fitting everything myself then   I'm planning on starting with the upgraded fuel pump. Was going to go with the corksport max flow fuel pump internals. From there I'll replace the downpipe not sure what with yet, if anyone's got any recommendations. Next step will be to fit a corksport stage 1 short ram intake and possibly the air box - with any opinions on the box? Not sure it's worth it really for the sake of just keeping on top of the maintenance of the filter. Then get the COBB Accessport V3 and get it mapped. Was thinking about upgrading the TMIC to an Airtec TMI instead of going for FMIC. Any other suggestions? Thanks for the replies guys. Seems like a great community to be a part of. Sent from my SM-N960F using Tapatalk
Post subject: Re: Hi All Posted: Mon Feb 24, 2020 6:54 pm |
RM BIK |
Ilikesleepers wrote: Spam man wrote: Ilikesleepers wrote: I've got the BBR 290 phase 1 running on my car that was put on by the previous owner, I've not had any problems so far, it's been on the car for about 4 years and 18000 miles. The software they use is ecutek I believe.
I've heard only good things about freektune... They charge you £75-125 to unlock it too. I've unlocked other BBR cars for people for free, as have other ecutek garages. I asked a local to me ecutek garage recently if they could unlock my ecu and they told me I'd have to go back to BBR. How is it done? Did said garage have ecutek though? Any ecutek garage can do it.
Ilikesleepers
Post subject: Re: Hi All Posted: Mon Feb 24, 2020 7:26 pm |
Bhp: 290
Spam man wrote: Ilikesleepers wrote: Spam man wrote: Ilikesleepers wrote: I've got the BBR 290 phase 1 running on my car that was put on by the previous owner, I've not had any problems so far, it's been on the car for about 4 years and 18000 miles. The software they use is ecutek I believe.
I've heard only good things about freektune... They charge you £75-125 to unlock it too. I've unlocked other BBR cars for people for free, as have other ecutek garages. I asked a local to me ecutek garage recently if they could unlock my ecu and they told me I'd have to go back to BBR. How is it done? Did said garage have ecutek though? Any ecutek garage can do it. They do mate, the garage is DMS performance in south Wales. They were very polite about it but said I'd have to go back to BBR due to the map being locked by them.
