Page 1 of 1 [ 4 posts ]
 Post subject: Mazda 3 mps crank timing
 Post Posted: Tue Oct 16, 2018 8:37 pm
Hi can any one tell me the correct crank pully timing mark for a 2007 mps cars running rough as hell and holding back had new vvt and cam chain peg it off at the bottom tdc and used cam plate to lock the cams but the bottom pully seems to be lined up with the 9th tooth every where I have read sure it says the 20th can any one confirm this
 Post subject: Re: Mazda 3 mps crank timing
 Post Posted: Tue Oct 16, 2018 9:30 pm
Maybe it slipped?
Did you use a full kit, not just vvt and chain, including new friction washers?
 Post Posted: Tue Oct 16, 2018 9:33 pm
BTW, tooth 20 is correct iirc.
 Post Posted: Tue Oct 16, 2018 9:54 pm
Yes complete kit bottom and cams are spot on it’s running on the 9th tooth at the minute on the bottom pullybas that what the mechanic seems to think it is but I’m surre it’s the 20th
Users browsing this forum: Google [Bot] and 7 guests
