Page 1 of 1 [ 11 posts ]
 Post subject: Bnr s4
 Post Posted: Sat Mar 18, 2017 6:23 am
Has thanked: 29 times
Hi I've spotted a bnr s4 turbo package on new age website. I am wondering if there is any stockists uk based as I am unsure how much I would get stung for with all the import taxes ect. Can anyone help please
 Post subject: Re: Bnr s4
 Post Posted: Sat Mar 18, 2017 8:32 am
Bhp: 395
lbf·ft: 385
Neil Ireland @ VIP motorsport
Sent from my SM-G935F using Tapatalk
Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
 Post Posted: Sat Mar 18, 2017 6:36 pm
Has thanked: 11 times
Been thanked: 22 times
Assume the worst (20% I think) but hope for the best (0%) when importing.
I'm not sure if you pay import fees on the postage as well as the items.
 Post Posted: Sat Mar 18, 2017 7:24 pm
Were you did get yours from and how much did you pay?
 Post Posted: Sun Mar 19, 2017 9:51 pm
Import duty and tax for car parts is 4.5% on the value (invoice) of the goods for duty, and 20% on the total value, including shipping costs (but not including the 4.5% duty). if ordering from New Age, Nate will reduce the invoice amount to try and save import costs...
Sent from my GT-I9505 using Tapatalk
 Post Posted: Mon Mar 20, 2017 11:55 am
Did you buy the package? How much did you pay please?
 Post Posted: Mon Mar 27, 2017 8:19 pm
With a big turbo. Do you still use a cobb/versa for a custom tune? Or is it though the ecu anyone please?
 Post Posted: Tue Mar 28, 2017 7:07 am
All tuning is down me via a Cobb or versatune regardless of how far you take the tuning process
 Post Posted: Tue Mar 28, 2017 7:15 pm
How bigger job is it fitting a turbo. Time scale wish as am also changing my dp too. Is the a garage that you can recommend. And other parts will I need to support a big turbo.
 Post Posted: Tue Mar 28, 2017 9:08 pm
A garage should not have to have the car longer than a day really. Supporting mods that are a must are upgraded HPFP internals, 3port boost control solenoid and a tune at a minimum.
 Post Posted: Wed Mar 29, 2017 7:56 pm
Big Dunc spent about three days lying under his 3 doing a turbo /downpie swap.
