 Post subject: Best place get upgrades
 Post Posted: Sat Feb 25, 2017 7:03 pm
Has thanked: 29 times
Hello I have recently got a gen1 mps looking to modify it. Can people help with reliable source for parts please as I have seen the bad reports about total mps.
 Post subject: Re: Best place get upgrades
 Post Posted: Sat Feb 25, 2017 10:09 pm
Neil Ireland V.I.P motorsports
 Post Posted: Sun Feb 26, 2017 1:54 am
lbf·ft: 339
Either Neil Ireland of VIP Motorsports or Nate from New Age Auto Parts
Mazda 3 MPS MK2
Velocity Red
BNR S4 Turbo - Bosch 3 Bar Map Sensor - Grimmspeed 3 Port Boost Control - HTP 3.5 Inch Intake - CPE TMIC - Jetex Catback Exhaust - ATP Catless Long Downpipe - Damond Motorsport Dual Oil Catch Cans - Damond Motorsport PCV Plate - Autotech HPFP - Forge V2 BPV - CFM Rear Engine Mount - Hardrace Front & Rear Droplinks - Whiteline Rear Anti Roll Bar - Team HEKO Wind Deflectors - Bayson R Front Splitter - Corksport Hood Scoop "Rice Scoop" - Eibach 5mm Wheel Spacers - MPSOC Stickers - Cobb V3 Accessport - J-Tune & Badge
 Post Posted: Sun Feb 26, 2017 6:14 am
Thanks. Will look into getting parts from else people.
 Post Posted: Sun Feb 26, 2017 6:38 am
Planning on a progressive build were to I start as I have already got an atp long down pipe. Not realising it would need tuning in. Have rear engine mount waiting to be fitted. Any help please thanks.
 Post Posted: Sun Feb 26, 2017 5:58 pm
First things I'd buy is high pressure fuel pump internal.....decent intake...(get one big enough to suit your needs down the line)..defo rear engine mount one of the best mods I bought tbh...and Cobb accessport or versatuner and drop Justin (djjut) a message..
Also advise listening to the guys in here they are full of great knowledge and advice
 Post Posted: Mon Feb 27, 2017 2:00 pm
What sort of power would I be looking at with full cat less downpipe cat back,Cobb v3, upto internals, fmic,intake bnr s4 please any one?
 Post Posted: Mon Feb 27, 2017 3:01 pm
If you have the correct size intake, 3.5 bar map sensor, 3 port etc etc then 400 is easily achieved
 Post Posted: Tue Feb 28, 2017 5:38 am
Best place to get an accessport from please? Rough prices and delivery time? Thanks.
 Post Posted: Tue Feb 28, 2017 6:26 am
New age.
I wouldn't touch Cobb though personally. Versatune would be my choice
 Post Posted: Tue Feb 28, 2017 7:10 am
What's the difference between the two
 Post Posted: Wed Mar 01, 2017 3:59 pm
hi and welcome.
if you want more information on which is the more preferred I am sure the wizard (DJJUT) will explain in a little more detail.
Hope you enjoy the mps
 Post Posted: Thu Mar 02, 2017 10:47 am
Would I be able too fit a cat less pipe with a stage one tune safely anyone please
 Post Posted: Thu Mar 02, 2017 11:03 am
Primary or secondary?
 Post Posted: Thu Mar 02, 2017 11:36 am
Fully cat less. It's an atp cat less long down pipe.
