Page 1 of 1 [ 4 posts ]
 Post subject: New Mk II 3 Owner
 Post Posted: Tue Feb 14, 2017 11:32 am
Well I bought myself a Mk II 3 MPS in black a few weeks back, so thought I'd say hello :thumbs:
I'm enjoying the car a lot so far, it's taken some adjustment having all that power through the front wheels but I think I'm getting used to it now!
Where's the best place to get parts for these cars? I think I've got a wheel bearing that needs doing.
Cheers :cheers:
 Post subject: Re: New Mk II 3 Owner
 Post Posted: Tue Feb 14, 2017 12:47 pm
:welcome: :mpsoc: Fella :thumbs:
Places for Parts
Neil Ireland (Facebook)
Nate (http://www.newageautoparts.com/)
Egde (http://edgeautosport.com/)
First Mods
Rear Engine Mount £90
Rear Anti Roll Bar or Sway Bar £140
High pressure Fuel Pump £3OO ish
Tyres LOL
 Post Posted: Tue Feb 14, 2017 1:14 pm
Bhp: 395
lbf·ft: 385
Welcome.... where r u based??
Sent from my SM-G935F using Tapatalk
Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
 Post Posted: Tue Feb 14, 2017 8:04 pm
Thanks for the parts places, will check them out - I can tell already that tyres are gonna be changed regularly!
I'm in the Cheshire area so if there's any MPS specialists around here that'd be good to know.
Users browsing this forum: No registered users and 17 guests
