Locky323
Post subject: Newbieeee here Posted: Mon Oct 03, 2016 7:49 pm |
Joined: Mon Oct 03, 2016 7:41 pm Posts: 21 Vehicle: MPS6
Hello everyone I've recently purchased a 6mps on a 57. Completely standard and full Mazda history. Basically I have had focus st corsa vxr and a Saab 2.8t in the past.. basically what's the first mods I need ? I have looked up and tried too research but don't really know anyone with a Mps, I'm after dropping it asap as it sits so high! No limits when it comes to modifying a car also.
DJJUT
Post subject: Re: Newbieeee here Posted: Mon Oct 03, 2016 8:45 pm |
| Global Moderator |
Has thanked: 65 times
Been thanked: 137 times
Hi and welcome. I would suggest a rear engine mount, intake system, 2nd decat, intercooler and hpfp internals to start (in any order). After that I would look at getting a tune and maybe a downpipe / upgraded turbo fitted.
Sent from my SM-G903F using Tapatalk
Locky323
Post subject: Re: Newbieeee here Posted: Tue Oct 04, 2016 3:14 am |
Thanks a lot mate, is there a website/company Everton's uses ?
Post subject: Re: Newbieeee here Posted: Tue Oct 04, 2016 11:15 am |
Edgeautosport for parts. Versatune for the remap software and the above DJJUT to map you
Gav1888
Post subject: Re: Newbieeee here Posted: Tue Oct 04, 2016 11:45 am |
Has thanked: 56 times
Been thanked: 28 times
Welcome to As Kenny (spam man) says..... http://edgeautosport.com
Users browsing this forum: No registered users and 9 guests |
