Neilied
Post subject: Morning all Posted: Mon Apr 25, 2016 8:48 am |
Hi all New to Mazda, MPS, and your site. Am collecting an 06 6MPS this week and after having been a very active member of other marque sites over the years. I am very aware of the advantage and abundant useful info available I found this site. So a big hello. Neil sat in Cardiff
gronow89
Post subject: Re: Morning all Posted: Mon Apr 25, 2016 10:39 am |
Joined: Tue May 08, 2012 8:40 pm Posts: 4176 Location: bridgend, south wales Vehicle: MPS3 mkI aero
Has thanked: 19 times
Been thanked: 46 times
Hi neil. Not far from me bud im in bridgend.
_________________ Wisseco pistons, Manley h beam rods, Arp main stud kit, Arp head stud kit, Fidanza ali flywheel, Cpe Balance shaft delete, Damond Egr delete kit, Inlet manifold butterfly delete, Coolent bypass, Cpe injector seals, Htp 3" intake, Aem cone filter, Bnr stage4 turbocharger, Grimspeed 3port bcs, Bosch 3bar map sensor, Ngk 1 step colder, 3" catless downpipe, 2nd decat delete, Cxracing custom pipes, Treadstone tr8 fmic, Sure short shift kit, Mme solid shifter bushes, Custom 676g gear knob, Xspower manifold, Devils own meth injection, Forge recirc valve, Autotech hpfp, Jbr thermal intake gasket, Hel stainless lines, Rear defuser, jbr air dam, Mk2 alloys, Versatuner.
gronow89
Post subject: Re: Morning all Posted: Mon Apr 25, 2016 11:05 am |
Also is the 6 you buying a local car or forum members?
Post subject: Re: Morning all Posted: Mon Apr 25, 2016 12:15 pm |
 to a fellow welshman
BuzyG
Post subject: Re: Morning all Posted: Tue Apr 26, 2016 10:18 pm |
Joined: Thu Jun 05, 2014 3:47 pm Posts: 151 Location: Cornwall UK Vehicle: other
Bhp: 148
lbf·ft: 138
Hi there Neil Welcome to the Forum.
Neilied
Post subject: Re: Morning all Posted: Wed Apr 27, 2016 7:11 am |
Hi all
Thanks for the replies. Don't think a forum car as I'm aware. Local though to South Wales. Just a few things to sort. Rear left brakes are binding and scraping and I've just searched the driver window controls as it only controls the driver door even when lock is off. Thanks all
gronow89
Post subject: Re: Morning all Posted: Wed Apr 27, 2016 7:43 am |
In regards to windows. Go to each individual window do it down then back up hold up for a couple of seconds you will here a click. This will then work off you drivers control. Rear brakes sounds like they are on metal. If your not far from bridgend and have no mechanical knowledge pop over i will take a look and change for you if needs be
Post subject: Re: Morning all Posted: Wed Apr 27, 2016 10:27 am |
This could be the one that's stupidly rusty underneath. Get it on a ramp before you part cash
CatsGoBark
Post subject: Re: Morning all Posted: Wed Apr 27, 2016 3:30 pm |
Joined: Sat Jun 13, 2015 2:35 pm Posts: 107 Location: Monmouth, South Wales Vehicle: MPS3 mkII
Been thanked: 4 times
MPS numbers are starting to increase in South Wales now
_________________ Mk2 3 MPS Crystal White Pearl
JBR Stage 2 Power Path Intake. Autotech HPFP, 2nd Cat and resonator delete, Turbosmart BOV, JBR 88a REM, Corksport TMIC, Cobb v3 and Jtune v3
Rear lights tinted red, brake calipers painted
Next to do - Custom exhaust and turbo time
gronow89
Post subject: Re: Morning all Posted: Wed Apr 27, 2016 9:21 pm |
Tell me about it. I bought one as i thought it be rare. Fml
HedleyNEUK
Post subject: Re: Morning all Posted: Thu Apr 28, 2016 4:39 pm |
Joined: Fri Feb 10, 2012 10:25 am Posts: 181 Location: North East Vehicle: MPS3 mkI aero
Been thanked: 7 times
Bhp: 317
lbf·ft: 326
_________________ Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
Neilied
Post subject: Re: Morning all Posted: Fri Apr 29, 2016 9:34 am |
Spam man wrote: This could be the one that's stupidly rusty underneath. Get it on a ramp before you part cash Hopefully not but if it is having owned an alfa gtv for 12 years I know a man who can. Had to have half of the floor and 5 of the 6 sills replaced yes 6 layers of sill on my alfa. Done the Windows however near side rear has no power do going to check the connection. Car has been standing for a while so going yo get a service and the rear brakes done then a full look over this week. Thanks for the offer of help too!! Ta Neil
gronow89
Post subject: Re: Morning all Posted: Fri Apr 29, 2016 7:47 pm |
No probs when its running dont be shy to pop to bridgend got a couple of nice mps around here.
autech
Post subject: Re: Morning all Posted: Mon May 02, 2016 7:11 pm |
Joined: Tue Nov 24, 2015 11:37 am Posts: 149 Location: Manchester Vehicle: MPS3 mkII
Has thanked: 21 times
Been thanked: 12 times
Welcome to the forum bud
_________________ Autotech internals // HTP 3" Full Intake // CP-E Top Mount // Stoptech Rotors/Pads // HEL braided lines // Corksport Hood Scoop // Cobb AP v3 // GFB Respons // Bilstein B12 Pro Kit // Whiteline Rarb and links // 4" Custom Tips // CFM 9 Peg Army // VVT done at Young Motors // J-Tuned
Gouldy
Post subject: Re: Morning all Posted: Tue May 03, 2016 1:11 am |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
Users browsing this forum: Google Adsense [Bot] and 4 guests |
