Page 1 of 1 [ 9 posts ]
 Post subject: Hi - And thanks already!
 Post Posted: Fri Apr 29, 2016 5:53 pm
Hi everyone,
I pickup my "new" MPS tomorrow. Really looking forward to it. Nearly bought some parts for it already until I came across the various threads about Total-MPS on here.
Oliver
 Post subject: Re: Hi - And thanks already!
 Post Posted: Fri Apr 29, 2016 6:24 pm
:welcome: to the club, what mps did you buy?
 Post Posted: Fri Apr 29, 2016 6:50 pm
Thanks, '08 3 MPS in Red with the Aero kit.
 Post Posted: Fri Apr 29, 2016 7:54 pm
Welcome!
:mpsoc:
 Post Posted: Sat Apr 30, 2016 10:34 am
Been thanked: 4 times
Welcome .! :mpsoc:
 Post Posted: Mon May 02, 2016 7:11 pm
Has thanked: 21 times
Been thanked: 12 times
Welcome along!!
Autotech internals // HTP 3" Full Intake // CP-E Top Mount // Stoptech Rotors/Pads // HEL braided lines // Corksport Hood Scoop // Cobb AP v3 // GFB Respons // Bilstein B12 Pro Kit // Whiteline Rarb and links // 4" Custom Tips // CFM 9 Peg Army // VVT done at Young Motors // J-Tuned
 Post Posted: Tue May 03, 2016 1:02 am
Hi and :welcome: along to :mpsoc:
Great to read that you've read the threads about TMPS already. Too often, people have already bought from them, and then come on here to ask why it's not turned up yet? :lol: :mad:
Love the mkI's in red.
 Post Posted: Tue May 03, 2016 11:15 am
:welcome: :mpsoc: Fella!
 Post Posted: Tue May 03, 2016 5:07 pm
Thanks, Very glad I always do a lot of research before I buy anything. The avoid TMPS thread here was the 1st result that came up on google when i searched for reviews. Hopefully other people are seeing it. :thumbs:
