Page 1 of 1 [ 8 posts ]
 Post subject: bnr3 setup and help
 Post Posted: Wed Mar 09, 2016 3:55 pm
Hi new to the forum after some advice I've just purchased a full bnr3 setup for my 2007 Mazda 3 MPS
Turbo
3" intake
Hpfp
3 bar map sensor
3 port boost controller
Cpe tmic
Cobb
So the situation is I am getting a downpipe custom made to marry up to my custom exhaust. Will the turbo fit onto the stick downpipe ? If so can I fit everything and flash on a base map from justin heath then be able to drive the car to get downpipe fitted?
All help appreciated thanks Karl
 Post subject: Re: bnr3 setup and help
 Post Posted: Wed Mar 09, 2016 4:29 pm
Yes, but you'll need yet another base map when the dp goes on.
 Post Posted: Wed Mar 09, 2016 11:47 pm
How easy is it remove the old turbo and replace it this is just my main concern at the moment
 Post Posted: Thu Mar 10, 2016 8:59 am
It's pretty straight forward tbh, just take your time.
Looking at 3 1/2 hours - 5 if you really take your time
 Post Posted: Thu Mar 10, 2016 2:14 pm
Ok thanks is it all accessible from the top of the engine
 Post Posted: Thu Mar 10, 2016 3:06 pm
Yes it is..... I find it best to have the front up on axle stands throughout.
 Post Posted: Thu Mar 10, 2016 3:57 pm
I have a couple of axel stands so I'm good there is that just to get access to the downpipe bolts or just for ease I presume I'll need some wd40 to release some of the bolts haha
 Post Posted: Fri Mar 11, 2016 2:32 am
From underneath you can get to the downpipe and turbo oil drain bolts.
