Page 1 of 1 [ 12 posts ]
 Post subject: I'm new.....
 Post Posted: Sat Jan 30, 2016 6:05 pm
Has thanked: 16 times
But we have two!
Twice the possibilities of ZZB's
Mk2 MPS 3 and A MPS 6
Thought I'd post here saying hi, as I need to get some posts on the board to make updating the project thread easier lol
 Post subject: Re: I'm new.....
 Post Posted: Sun Jan 31, 2016 6:20 am
Welcome to :mpsoc:
 Post Posted: Sun Jan 31, 2016 8:27 am
Hello and welcome. :)
 Post Posted: Mon Feb 01, 2016 4:11 pm
Welcome to the forum mate :)
Two eh, whats the current mods?
 Post Posted: Mon Feb 01, 2016 4:16 pm
The 6 was mine so a lot lol.
 Post Posted: Mon Feb 01, 2016 4:34 pm
Aaaah shows I should read before posting LMAO :p
Mind you I like the weight the cars lost now
 Post Posted: Mon Feb 01, 2016 4:52 pm
Has thanked: 21 times
Been thanked: 12 times
You in Manchester mate? Sure I've seen that REG before on the 3!
Autotech internals // HTP 3" Full Intake // CP-E Top Mount // Stoptech Rotors/Pads // HEL braided lines // Corksport Hood Scoop // Cobb AP v3 // GFB Respons // Bilstein B12 Pro Kit // Whiteline Rarb and links // 4" Custom Tips // CFM 9 Peg Army // VVT done at Young Motors // J-Tuned
 Post Posted: Mon Feb 01, 2016 5:53 pm
Has thanked: 215 times
Been thanked: 127 times
Looks a good driveway!!!
 Post Posted: Mon Feb 01, 2016 10:22 pm
Bhp: 317
lbf·ft: 326
Welcome neil ;) :D
Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
 Post Posted: Tue Feb 02, 2016 12:57 am
:welcome: :mpsoc: 2Up I SEE LOL!
 Post Posted: Tue Feb 02, 2016 8:27 am
Hi and :welcome: along to :mpsoc:
My what a lovely pair you have! :lol:
 Post Posted: Tue Feb 02, 2016 9:48 am
Cheers Guys, thanks for the warm welcome.
It's been an expensive few weeks of ownership lol
