Page 1 of 1 [ 7 posts ]
 Post subject: port1 running lean
 Post Posted: Sun Oct 18, 2015 8:37 pm
Hi New on here got a code reader reading 2096 deleted it just comes back is this a big problem would using car damage anything.also what is the problems
Any advice welcome cheers
 Post subject: Re: port1 running lean
 Post Posted: Sun Oct 18, 2015 11:29 pm
My money is you've a mkii 3 yes?
 Post Posted: Mon Oct 19, 2015 7:39 am
Yes only had it 2 month New wishbone New rem now this
 Post Posted: Mon Oct 19, 2015 7:37 pm
Any advice please
 Post Posted: Mon Oct 19, 2015 9:42 pm
:mad:
 Post Posted: Wed Oct 21, 2015 8:43 am
viewtopic.php?f=29&t=12529
 Post Posted: Wed Oct 21, 2015 11:21 am
Bhp: 395
lbf·ft: 385
had this come up just the other day... was a software update as said. £45
Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
