Page 1 of 1 [ 5 posts ]
 Post subject: New wheels
 Post Posted: Sat Sep 05, 2015 10:03 am
Has thanked: 14 times
Been thanked: 18 times
Seen these wheels and had to buy them. Cosmis S1 9.5x18 with 15mm offset.
They will be a pain to fit but I am going to get it done right, with the arches cut out, extended and welded back wider. I know it is a lot of messing about and will cost a few pounds, but I want these wheels and I want them to fit right, with 255 wide tyres to protect the wheels and have the correct ratio's and rolling radious etc. Dont want any arch rubbing or problems from being lowered.
Wheels will be here on Monday and I will chat to the bodyshop once I have the wheels to test fit. Shall look forward to see how they will look and how the 6 will look with wider arches :D
Kev :thumbs:
You do not have the required permissions to view the files attached to this post.
Tuned with Image
Alcon 6 pot Brake Calipers with 365mm Discs, Cosmis S1 18x9.5 inch alloys and 265/35/18 tyres
Treadstone Front Mount Intercooler Kit. TR1035 core, clamps with piping, and a crash bar!
CorkSport Power Series II SRI, Blitz Bypass Valve
Cobra Single Exit Exhaust and Decat
CorkSport Upper Control Arms adjustability from -0.2 degrees to -2.0 degrees for added and improved control, spherical bearings replace the soft rubber bushings used in OEM and arms for more precise suspension settings
Corksport Rear Camber Arms +/- 5 degrees of camber adjustment
AWR Engine Mount Set
Turbine Tech forward Differential Mount Brace
CPE xFlex™ Rear Differential Mount
Whiteline Upgraded Anti Roll Bar
Bilstein B12 Pro Suspesion Kit
RX8 R3 Recaro's, Retrimmed RX8 R3 Steering wheel in Leather and Alcantara with Red stitching. James Barone Racing - Short Shift Kit and JBR Heavy Gear Knob.
Evo X rear Spoiler LED rear lights
VersaTuner map
 Post subject: Re: New wheels
 Post Posted: Sat Sep 05, 2015 11:05 am
Bhp: 290
lbf·ft: 300
Really looking forward to seeing this once its done!
JBR 3"inch widepath intake, Autotek HPFP internals, Cobb V3 AC Sure Charge Tubes Vibratechnics REM GFB Response BOV 50/50, CPE TMIC
Moog Rear droplinks
watch this space ;)
Coming soon
ARK Performance Cat Back exhaust
18"inch Rota Grid Drifts - Eibach Lowering Springs
White Line 27mm Rear Sway Bar
Stop Tech Drilled Front and Rear brake discs - Stop Tech Stainles Steel Braided Hoses
 Post Posted: Sat Sep 05, 2015 12:25 pm
Has thanked: 372 times
Been thanked: 101 times
Bhp: 282
lbf·ft: 317
WOW!!!! This sounds very interesting. Try and get the body shop to take some pics or a film of the process to widen the arches?
The 6 looks sporty enough with 225's never mind 255's :thumbs:
 Post Posted: Sat Sep 05, 2015 12:28 pm
:eek: wow can not wait to see the final result! I thought I was nuts going for 19s needing the arches rolling. This is a whole other level nuts! :thumbs:
Gotta love the concave!
 Post Posted: Sat Sep 05, 2015 7:11 pm
Bhp: 317
lbf·ft: 326
Epic levels of coolness with theses ;)
Finally Purchased May 2015- 3 MPS Mk1 Aero Facelift Crystal White Pearl~ Sure Aeros Intake and TIP/GReddy TI-C 3" Catback/Cobb AP v3/J-Tune Rev5/Autotech HPFP Internals/GFB TMS Respons BOV/Heko Wind Deflectors/Cobb Shift Knob/Torque Solutions Solid Shifter Bushings/Dewipered Rear window/Uprated Xenon's/HID Main/Interior LED Conversion/RallyFlapz and Plenty Purple Bits............ Made 317bhp (270whp) and 326lb/ft at the national meet May 2016 ****** Currently ZZB, Will rebuild over time
