Page 1 of 1 [ 10 posts ]
 Post subject: Hey all - new member
 Post Posted: Wed Jun 10, 2015 11:50 am
Hello everyone,
New member here, I bought a Red Mazda 3 MPS MKII last weekend after doing a fair bit of research online. After being a die hard Honda fan it is an interesting change coming over from the high revving NA VTEC.
That said I am loving the car so far, very fun to drive and loads of space inside!
I'm going to give it a little while to get used to the car before I start looking at some understated mods focusing mainly on handling I think because while it is fun to put your foot down it sure likes to torque steer!
Anyway looking forward to becoming part of the community and joining some meets soon. :)
 Post subject: Re: Hey all - new member
 Post Posted: Thu Jun 11, 2015 11:42 pm
Has thanked: 168 times
Been thanked: 113 times
Hi and :welcome: along to :mpsoc:
This is a great community. There are so many friendly helpful people on here.
:thumbs:
Most importantly, J Tune!!!!!
 Post Posted: Fri Jun 12, 2015 12:06 am
:welcome: To :mpsoc: Best Club for this platform!
 Post Posted: Fri Jun 12, 2015 8:46 am
Welcome tot he forum mate :)
Hint: Hide yer wallet :p
 Post Posted: Fri Jun 12, 2015 9:01 am
 Post Posted: Tue Jun 16, 2015 7:20 am
 Post Posted: Tue Jun 16, 2015 5:42 pm
Welcome along!
Definitely hide your wallet, only owned mine for two months and this forum has helped me spend money!
 Post Posted: Sun Jun 21, 2015 7:08 pm
Hi and welcome along, I too was a fellow Honda "follower". 2 x ATRs, 2xEP3s and an EG!
 Post Posted: Fri Sep 11, 2015 10:03 pm
 Post Posted: Sat Sep 12, 2015 3:20 pm
Hi and welcome to :mpsoc:
The torque steer is a feature of most high power turbo hot hatches but a few choice mods (rear engine mount, better rubber etc) can help reduce it.
