Page 1 of 2 [ 20 posts ] Go to page 1, 2  Next
 Post subject: New member
 Post Posted: Sat Jun 13, 2015 8:10 pm
Bhp: 395
lbf·ft: 385
Hi all. Take delivery of my MPS on Friday.... Can't wait
 Post subject: Re: New member
 Post Posted: Sun Jun 14, 2015 12:14 am
:welcome: to :mpsoc: :thumbs:
 Post Posted: Sun Jun 14, 2015 6:15 am
Bhp: 395
lbf·ft: 385
Have to say, after my 1/2 hr test drive in Saturday, I was thorough impressed. Very much a wolf in sheeps clothing. Will be looking to eak a little more power out of it though.
 Post Posted: Sun Jun 14, 2015 8:02 am
Hi and :welcome: along to :mpsoc:
Which mps did you get and what colour?
Do you have any plans for it?
 Post Posted: Sun Jun 14, 2015 9:39 am
:welcome: to the owners club :thumbs:
 Post Posted: Sun Jun 14, 2015 10:29 am
Bhp: 395
lbf·ft: 385
Mk 2 in white with black alloys. Totally standard at the mo. Probably just a map as it's the wife's daily drive and my weekend hack. Was looking at a litchfield map???
 Post Posted: Sun Jun 14, 2015 1:40 pm
Bhp: 395
lbf·ft: 385
Got a white mk2.
 Post Posted: Sun Jun 14, 2015 5:59 pm
Hi and Welcome to the family.
Update your profile, we have a great buyers guide and tuning section
 Post Posted: Sun Jun 14, 2015 6:57 pm
Bhp: 395
lbf·ft: 385
Updated and subscribed fully.
Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
 Post Posted: Sun Jun 14, 2015 7:27 pm
Bhp: 395
lbf·ft: 385
Replies seem to take an age to post. Is this normal??
 Post Posted: Mon Jun 15, 2015 12:35 am
Your first few posts all have to manually approved, just an anti spam thing we do to all new members to ensure your not a spammer/bot
 Post Posted: Mon Jun 15, 2015 5:31 am
Bhp: 395
lbf·ft: 385
Ah all sorted now. I seem to be up and running properly.
 Post Posted: Mon Jun 15, 2015 8:28 am
Nice.
If your looking at getting it mapped, I personally would stay clear of most companies offering maps no matter how well renowned hey as with other cars.
The mps is notoriously difficult to map well. I and most of the members on here would recommend an emap by Justin Heath aka DJJUT. He's mapped over 160mps's and is a really nice guy!
 Post Posted: Mon Jun 15, 2015 8:41 am
Bhp: 395
lbf·ft: 385
Interesting. Where does he work out of??
 Post Posted: Mon Jun 15, 2015 11:58 am
He works from home.
Basically you buy either a cobb or VersaTune software. He will write a base map for you and email it to you. After flashing it to your ecu, you take data logs and send them to Justin who tweaks the map to make it safer, more reliable and more powerful!
This is usually done between 5-8 times.
In theory it should be better because your map is set up for road conditions not a dyno and a fan.
